When I was checking out scarymyths DRZ at the showroom, I did notice that the main jet access is a little tight because of the starter.
This is the same carb as on my WR400 (1999). I can get at the main without rotating the carb but have to rotate to access the needle jet (top of the carb) and pilot jet (bowl).
Sounds like you'll have to rotate to get to the main? When I saw the DRZ at the dealer, my thought was that the boal drain/main would be tight but with the right tools, do-able. The boal drain (bottom of the carb where main jet is accessible from) comes off with a 14mm, probably need a open end or closed end wrench. Then the main is a 6mm (I think). You can probably buy a main jet tool from your local shop or elsewhere and cut it down/modify it to get it to work. There are many jet tools available via aftermarket companies too so it may take some digging to find one that can be modified to suit your needs.
To rotate the carb all I have to do is remove the throttle cables off the right side of the bike, loosen the boots that hold the carb in place (both sides of course), and take off one hose that goes into the engine. Doing this allows access to any and all jets without removing the whole damn thing although it is still tight. Hopefully, your DRZ is the same way.
I know it sounds tedious, but after doing it once or twice, it really isn't that bad. Plus, it's good to know how to adjust the throttle linkage anyway eh?
Please try this and report back on your success/failure.
Thanks,
Bryan...
