Adjusting Valves.. Hard?
24 replies to this topic
  • motometal
Posted August 18, 2007 - 08:59 AM
#21
I just did this (for the first time) on my '93 xrl last weekend. According to Clymer, you turn the crank to TDC on the compression stroke. All four valves will have play in them on the compression stroke and all four can be adjusted. If you are at TDC and two of the valves are open (no play), you are on the top of the exhaust stroke and the crank should be turned another 360 degree.
I am not convinced that my fat, flat auto feeler gauges were the right tool for the job. It seemed there was a lot of bending and twisting to get the gauge into the gap. I think next time I'll get gauges specifically for the task.
Good luck.
I'm probably using the same ones you have, just carefully bend the last 1/2" or so at a bit of an angle as needed and they will work fine. To be correct, the feeler shouldn't be rubbing on the head cover (the area where the cap screws in).
  • Frank ZX
Posted August 18, 2007 - 09:01 AM
#22
I tryed to adjust my valves yesterday.I put piston at TDC,had play in all 4 valves.When I put the wide bulky feeler between valve and rocker arm,it seemed too tight.So I left it alone.I had the correct size gauges 0.10 and
0.12mm.Is it common for the valves to get tight,or did I just have the feeler gauge at the wrong angle?
  • martinfan30
Posted August 18, 2007 - 09:12 AM
#23
it is normal for a valve to get tight as the seat is beaten up into the head.
  • motometal
Posted August 18, 2007 - 05:44 PM
#24
Buy a whole set of feelers, they are cheap from the auto parts store. Start with one of the really thin ones. Bend them a bit as needed. Get a "feel" with the looser ones, then work your way up until you start to feel drag. Slight drag is where you are at for a measurement. It takes very little turning on the adjuster to make a difference. For that reason, after adjusting I usually just snug the nut, check, if it's ok I tighten fully, then double check. This is usually a pretty uneventful operation (no adjustment req) unless you have put a ton of miles since the last check, or have recently put in new components such as a new cam, valves, etc.
  • XR650L_Dave
Posted August 20, 2007 - 07:53 AM
#25
If the seat mushes, or gets beaten into the head, or if the valve face cups, or if the stem stretches, the clearance will indeed get smaller.
I have heard of an XRL valve seat coming loose, but not of them being bashed into the head.
Dave
  • 9 replies
  • 22 replies
  • Hot  60 replies
  • 4 replies
Honda XR650L 2017
  • 0 reviews
