Green Slime?
7 replies to this topic
  • ScottyR
Posted September 04, 2000 - 03:20 PM
Any one try this stuff? How did it work? I am going away for 3 days this weekend to ride in some really rocky terrain and dont want to get a flat. Any other suggestions...
  • Guest_Guest_*
Posted September 04, 2000 - 03:56 PM
I have uesd the green slime for years it works geart,put it in the tube air up the tire and go ride to move the slime around inside the tube. :)
monty
  • mcarp
Posted September 04, 2000 - 05:35 PM
I seemed to get flats often in the past riding in the sticks (and locust trees) in Ohio. So I did what you are thinking and added some slime--haven't had a flat in 6 months since using it and one time I *knew* I had rode through a locust patch (long, sharp,spiney thorns) and virtually guaranteed a flat. Maybe they work. I guess the real test will come after more time as passed, but so far so good!
You may notice the front end steering a little slower (theoretic, I didn't notice anything) due to the increased rolling mass, I think you need about 8oz (1/2 lb) of Slime per tire! Or maybe it will add a little flywheel momentum effect--again I didn't notice any change but some riders might.
  • Kermit
Posted September 04, 2000 - 06:27 PM
Hey Scott I live in Tucson real nasty stuff here sharp rocks,cactus, HUGE thorns buy it you won't regret it beats triyng to patch it out in the middle of no where!!! I always put in new tubes when I change tires also put baby powder on the tube, old trick, keeps tube and tire from becomin' one.
Kermit
  • Dougie
Posted September 05, 2000 - 02:04 AM
I use to use it on my old bike. It worked OK, but I still got a few flats though. Plus, it was a mess when I changed my tires and I had to let the air out of the tube.
  • Guest_Guest_*
Posted September 05, 2000 - 08:06 AM
In rocks you need more AIR.
  • Guest_Guest_*
Posted September 05, 2000 - 08:50 AM
From the topic header of this thread, I thought the subject was a political add for Ralph Nader. Green slime would be a good name for the Green Party.
  • BruceWA
Posted September 05, 2000 - 01:32 PM
Haven't used the green slime in sometime. Still got flats with it. Changed to using metzler heavy duty tubes about three years ago and have had only 1 flat since. These tubes are great! Or maybe I'm not riding as aggressively???
