426 idle problems
6 replies to this topic
  • DublinCA
Posted August 12, 2007 - 01:30 PM
My bike starts fine and idles fine after starting, but as soon as I give it some throttle it will go into a fast idle. If I adjust the idle to bring it down I have to turn it back up right away or it will die. I cleaned the carb reall well and I'm at 1 1/4 turn on my pilot screw. Any ideas?
  • TuningFork426
Posted August 12, 2007 - 03:23 PM
I think thats normal, I just set my idle without touching the throttle.
  • flintlock28
Posted August 12, 2007 - 03:47 PM
Sounds like you need the next larger size Pilot Jet. I believe this is called a "Hanging Idle", and is from the pilot circuit not getting enough fuel.
  • DublinCA
Posted August 12, 2007 - 04:28 PM
I just replaced my pilot screw with one that comes out the bottom of the carb so you can adjust it with your fingers. I bought the one recommended. I did start having this problem when I replaced the pilot. Might that be my problem?
Posted August 12, 2007 - 05:34 PM
Did you readjust it per the manual, or just screw it in?
  • DublinCA
Posted August 12, 2007 - 06:24 PM
I did use the manual. I'm at a 1 1/4 turns right now after some adjustment.
Posted August 12, 2007 - 08:48 PM
If you don't see an obvious air leak, check your valve clearances. The intakes may be tight.
  • Hot  491 replies
yz400f throttle bog by yz400fmaniac
  • Hot  28 replies
  • 0 replies
  • Hot  36 replies
  • Hot  28 replies
