Requesting jetting recommendations
3 replies to this topic
  • Guest_Guest_*
Posted September 01, 2000 - 06:14 AM
I’m installing a FMF PC-IV2 w/Powerbomb. Does anyone have jetting recommendations.
99 WR400 with WR timing and the airbox cover removed. Altitude is 500’-1000’?
Thanks in advance,
Mike H.
St. Louis MO
USA
  • Gary_Kessler
Posted September 01, 2000 - 06:51 AM
Hey Mike. .
There's a wealth of comments about jetting you WR if you scan down further in the notes. Also go to www.thumpertalk.com and there is a specific section on jetting your bike. You'll find what you need there. Remember when you jetting, air-filter type, airbox lid on/off, WR or YZ timing and exhaust type all make a difference. . . .
'00 WR; YZ modified, DSP exhaust system & UNI air, Jetting by Clark, James & Bryan. . .
  • fershy
Posted September 01, 2000 - 07:13 AM
with wr timing and standard needle you could run about a 172 main with a powercore iv. I run a 170 at higher altitudes, and same exhaust.
fershy
  • James_Dean
Posted September 01, 2000 - 07:30 AM
See "Jetting EKP vs DVP"
