Yamaha Dual Sport Kit
7 replies to this topic
  • bicyclebob
Posted August 09, 2007 - 11:25 PM
I found the actual Yamaha parts list/kit for a homoginaztion? conversion for a WR. I didn't copy the address:banghead:. I think it was at the Yamaha Australia site but I can't find it. Anybody have any ideas?
  • S2P
Posted August 10, 2007 - 01:05 PM
That post was from down under, They have no "kit" in the states. I've asked several dealers.
  • RJB
Posted August 11, 2007 - 06:10 PM
I have the complete parts list for the ADR (Australian) on road kit. I do believe it is not supplied in the US at all. If you want I can post the list all the same.
  • bicyclebob
Posted August 11, 2007 - 07:39 PM
Thanks RJB. If you could post it that would be quite helpful.
  • B-Rock
Posted August 13, 2007 - 06:32 AM
Yes please RJB!!! :thumbsup:
  • Humunn
Posted August 15, 2007 - 06:31 AM
If you're looking for a reliable, low tech but legal kit check out dual sport america (formerly californial dual sport). I installed one on my 07 and it works great. No electical/stator mods needed. Runs with stock headlight and tail light.
Greg
  • bicyclebob
Posted August 23, 2007 - 08:13 PM
This list is brought to you by our friend RJB. :applause: Give him some gas! The next question is how do we get this stuff in the good old US. Anyone have any ideas? I tried the net at the US sites and struck out. My dealer says he can't get them.
WR250FW/WR450FW
2007 ADR MODEL
2007 WR450FW 5TJG 1F5TJ-100E1
2007 WR250FW 5UMG 1F5UM-100E1
ADR Parts List
1 Headlamp unit with Globe and Holder 5UM-H4300-00-AD
2 Headlamp Cowling 5UM-H4111-00-AD
3 Headlamp Sticker 5UM-H4141-00-AD
4 Hi Beam Light 5UM-84301-10-AD
5 Turn Signal Light 5UM-84301-00-AD
6 Key On Light 5UM-84301-20-AD
7 Wiring Harness for Warning Lights 5UM-84346-00-AD
8 Side Reflector (2) 5UM-85130-00-AD
9 Rear Rego Plate Holder Number Plate 5UM-F1685-20-AD
10 Rego Plate Holder Subframe. U-Shape 5UM-F1671-00-AD
11 Rego Subframe re-inforcement 5UM-F1666-00-AD 1
12 Top Retainer Plate with WR Mark 5UM-F162G-00-AD 1
13 Rego Plate Light 5UM-84745-00-AD
14 Rear Reflector 5MW-85130-00-AD
15 Blinker Front RH 5PH-83320-00-AD
16 Blinker Front LH 5PH-83310-00-AD
17 Blinker Rear RH 5PH-83340-00-AD
18 Blinker Rear LH 5PH-83330-00-AD
19 Flasher Relay 12V 3 Pin 5GS-83350-01-AD 1
20 Rubber Mount for Relay 5GS-83352-00-AD 1
21 Bracket for Relay and Horn 250 5UM-83375-10-AD
22 Bracket for Relay and Horn 450 5TJ-83375-00-AD 1
23 Blinker Bracket Front LH 5XE-83318-00-AD
24 Blinker Bracket Front RH 5UM-83328-00-AD
25 Comp Carb Stopper Screw (WR450F) 5JG-14591-00
26 Comp Carb Stopper Screw (WR250F) 5NL-14591-00
27 Wiring Harness 5UM-82590-40-AD
28 Brake Light Switch Front 5PH-82530-00-AD
29 Brake Light Switch Rear 5UM-82530-00-AD
30 Horn 5GS-83371-02-AD
31 Horn Amplifier 5HP-8337A-01-AD
32 Left H/Bar Switch Assy 5UM-83972-01-AD
33 Spacer for Hot Start Lever 5UM-8394S-00-AD
34 Right H/Bar Switch Assy 5UM-83975-00-AD
35 Ignition Lock Assy 5UM-82510-21-AD
36 Chain Guard Assy 5GS-22311-10-AD
37 Front Chain Guard Collar 3JD-21748-00
38 Mirror Set (L+R) 5UM-W2628-01-AD
39 Sidestand Return Plate 5UM-F7315-00-AD
40 Sidestand Return Bolt 5UM-F7317-00-AD
41 Handguard Set (Blue) 5UM-26140-10-AD
42 Rubber Plug inlet manifold 16G-13569-00
43 Clip for Rubber plug (inlet manifold) 90467-10039
XX LCD Taillight 5UM-84710-E0
  • RJB
Posted August 24, 2007 - 06:51 AM
Folks, the parts in Oz are expensive. For example, the wiring harness runs about AU$213. A single indicator is about AU$38 and to buy all the bits for the rear licence plate holder is around AU$300 these days from a dealer there. I would hate to price it all up, but I'm sure it would be pretty darn expensive. The kit the dealer fitted to my bike here in Brunei (think it is more a pre 2007 kit) was around $800 and isn't quite right. I'll chase him up and see what (if he can get one) he'll charge for the 07/08 kit.
