New To '05 650/ Backfire
5 replies to this topic
  • hatterasman
Posted August 09, 2007 - 05:49 PM
i went from dr 200 to this 650 which was the right choice. I bought it with 1500 miles and was wondering if the bigger bikes are going to backfire. As I shift thru gears it will sometimes do it. I can fix anything on my trruck but bikes are new to me. Any help for the new TT dummy?
Thanks
  • martinfan30
Posted August 09, 2007 - 05:57 PM
Thanks
is this an 05 650R or 650L? if it is stock, the lean jetting will cause popping and occasionally a good backfire. how long has it sat? could be a restriction in the pilot circuit too. all the info you can provide about the bike will help with a pinpoint answer. by the way, welcome to the pig family!lol!:busted:
  • hatterasman
Posted August 09, 2007 - 06:07 PM
wow you guys are quick.... it is the L. It does have a KN air filter.. not stock? which made me think it would run lean if he didn't do anything to the carb. It has not been sitting.... in a months time of having it I have put 1200 miles on it. To and from work. trying to save some $ on gas. the truck loves the fuel
  • martinfan30
Posted August 09, 2007 - 06:31 PM
get rid of that k&N! use a uni filter. k&n doesnt really filter as well as a properly oiled uni.you are right, that filter will require a rejet to more rich. what is your elevation? do daves mods or buy a dynojet kit. this will cure the b.firing/popping.
  • hatterasman
Posted August 10, 2007 - 09:10 AM
I might be below sea level... haha Out on an island of NC. Is it possible to just raise the pin in the carb or do I have to rejet. Thanks for the help.
  • Thorpey
Posted August 10, 2007 - 09:26 PM
All the above as well as this below. I copied it from an earlier post. The intake valves seem to tighten up alot more frequently than the exhaust.
Have you checked your valves? Valves heats up, clearance goes away, intake valve open a little at TDC. BAM! Might want to checkum. Easy to start cold, hard to start hot + backfiring could be valves. Make sure you are off the auto decompressor if you do.
Here's a link if you've never done them: http://www.xr650r.us/tech/valves.pdf
If I'm dealing with a new-to-me bike I always confirm proper valve clearance before attempting jetting. It can save alot of time and frustration. And if the clearance checks out good..., then YOU know it 'cause YOU checked them!
  • 22 replies
  • 17 replies
Honda XR650L 2017
  • 0 reviews
  • Hot  28 replies
Which thumper motor for a street tracker? by woz
  • Hot  29 replies
