Scotts steering damper - will it fit?
4 replies to this topic
  • Suikerland
Posted August 09, 2007 - 01:59 AM
Will a Scotts damper with oil-dipstick mounted post fit on an XRR with Acerbis 6 gallon tank and stock odometer?
Is there enough space there for the whole unit?
thanks
  • tdamore
Posted August 09, 2007 - 03:21 AM
thanks
edit - just reread your post and realized that you are doing a dipstick mount so this probably won't help you.
Not sure about it with the six gallon tank, but mine fits fine with a clark 4.3. It's sub mounted though and it is kind of a pain to check the oil but that is more due to the tank then the stabilizer. I'll see if I can dig up some pics of my setup
  • Denn10
Posted August 09, 2007 - 06:07 AM
Why worry about mounting and just get the mount that goes to the front and no worries about tank or anything else? Ive seen pics of some scotts on previous threads here.
  • Suikerland
Posted August 09, 2007 - 09:35 AM
the front mount means I definitely have to move my stock speedometer / odometer (it's a Euro-issue XRR) and I'm looking for the simplest option... the less moving of parts the better...
  • Denn10
Posted August 09, 2007 - 11:24 AM
ahhh ok did you search at all here? find anything?
