grey wire mod
4 replies to this topic
  • Appalachian DR
Posted August 08, 2007 - 05:52 PM
Will this get rid of the off idle bog. I need better throttle response. If I disconnect the grey wire, is there anything else that must be done along with it to make her run right. I'm under the impression the cut throttle stop is only an option, not a must do.
So should I do it and will it cure the bog and my blues?
Thanks
  • jams229
Posted August 08, 2007 - 06:30 PM
NO - the grey wire mod will not help with your bog issue.
You must jet your bike properly.
Check the stickies for advice.
  • BIG HAL
Posted August 09, 2007 - 08:13 AM
Use the JD jetting kit and your good to go!!
  • Pooley
Posted August 09, 2007 - 11:25 AM
Off idle bog problems? Check out the O-ring mod.
  • redswr
Posted August 09, 2007 - 11:49 AM
Boysen Quickshot2 seemd to help out quite a bit
