fluids on a 04 yz85
6 replies to this topic
  • crazy lil punk
Posted August 08, 2007 - 01:53 PM
hey,
I have a 2004 yz85.
What kind of coolant do i need to get?
How much, and what kind of oil should I put in the crank case?
thanks, Joe
  • crazy lil punk
Posted August 08, 2007 - 05:38 PM
i need help guys, please....bump
  • cr85_supermini03
Posted August 08, 2007 - 08:31 PM
50/50 water antifreeze and for tranny oil i use bellray gear saver. sorry if my spellings off sticky keys are on so i have to figure out witch key is witch
  • Rootuser
Posted August 08, 2007 - 08:40 PM
For the gear box I like Rock Oil personally and 50/50 is a good mix as mentioned above.
  • crazy lil punk
Posted August 09, 2007 - 03:58 AM
okay, thanks alot guys, and is there something to measure the oil that comes with the oil, I know its like 500mm or something that has to go in there? and regular anti-freeze, nothing special?
  • yz450vet
Posted August 28, 2007 - 03:10 PM
My son's yz 85 takes 5ooml of oil. The thing I can't figure out is how to check the oil level after you've filled it!! I heard there is a screw on the opposite side of the engine that you can loosen and as long as oils flows out of it you're at the right level. Can anyone confirm this and do you have any photos of where this screw is.
  • rusky
Posted August 28, 2007 - 05:47 PM
for radiator fluid ive always drained the stock stuff and used engine ice, makes the bike run a little cooler if you are riding in sand or just like to keep the revs up.
what bike? KTM,RM,YZ,KX,or CR 125 by Numsa Hul
  • 8 replies
What would you buy? by 2000YZ250
  • Hot  45 replies
First Harescramble by 2000YZ250
  • Hot  36 replies
Brand new rider, yz 125? by zander
  • 4 replies
Should I replace some parts / What to look for / check? by lephil
  • Hot  28 replies
