CLARK- JETTING
7 replies to this topic
  • Guest_Guest_*
Posted August 16, 2000 - 01:05 PM
Clark,
I recently installed a dvp needle in my 00. I installed it in position #4.This change got rid of all the irritating surge while road cruising. As yo may remember, i am running 178 main, 48 pilot, stock exhaust with Stoker dual sport insert. For my usual 1500'- 6000' riding am i good to go with the needle position or will i get more hit with the needle at # 3?
  • Clark_Mason
Posted August 16, 2000 - 04:22 PM
Glen
Your bike should run just fine form 1500 to 6000ft with the setup you describe.
Personally I use the same jetting only switch to a DVR #3 or 4 if riding above 5000 to 6000 feet for a whil--like a week long riding trip. But just for everyday trail use like up to Gorman (4000 to 8000ft) day ride I do not change anything except close the fuel screw a 1/2 turn.
Clark
  • Tim_in_WA
Posted August 16, 2000 - 08:00 PM
Glenn,
Are you running WR or YZ timing, and how is the power throughout the throttle range with your current jetting setup? Also, do you get any hesitation right off idle?
  • Guest_Guest_*
Posted August 17, 2000 - 04:09 AM
Thanks Clark, i also feel that this is good all around jetting for my varied riding conditions.
Tim in Washington, i have wr timing, and have very little hesitation when whacking open the throttle at low speed. The stock pilot jet (42) had major stumbling off the bottom.
  • Clark_Mason
Posted August 17, 2000 - 07:45 AM
Glen
I thought you were YZ timed and it turns out you have WR timing. With WR timing if you want to use the DVP needle might want to try #6 or #5 clip positions as the the WR likes fuel a little sooner in the throttle opening. A 175 to 178 MJ should be fine. I would not use a DVR needle in a WR timed bike unless you are above 12000 feet.
sorry for the misunderstanding.
Clark
  • Guest_Guest_*
Posted August 17, 2000 - 09:23 PM
Is the dvp right for my setup? it came stock with DRS #3, i changed to current jetting but with a DVR at #4 on recommendation from Stroker. I thought the stroker set up ran very strong but had the major surge and miss at cruising speed. As i stated in the earlier post the DVP # 4 got rid of that and now you think that i will get better result with the richer clip positioning?
Glenn
  • Guest_Guest_*
Posted August 17, 2000 - 01:06 PM
Clark,
I'm settled on the pilot, main and airscrew,
whats the deal on the needle? DVP or DRS and what clip position?
Glenn
  • Clark_Mason
Posted August 17, 2000 - 05:16 PM
Glen
With the WR Timing I would go for the DVP vs the DVR and the clip between #4 to #6 start with a #5.
Clark
