Hex head carb screws?
12 replies to this topic
  • TrailRiderXRL
Posted August 08, 2007 - 12:09 PM
Where can I get hex head carb screws for my XRR?
Thanks
  • martinfan30
Posted August 08, 2007 - 12:34 PM
Thanks
check this out:
http://houseofmotorc...0R/2005/1134561
  • tdamore
Posted August 08, 2007 - 04:38 PM
I bought mine at home depot but if you have a Orchard Supply near you they should have them also. I think the 4 that hold the float bowl and the two on top are 3mm and the one that holds the idle screw bracket on is a 4mm.
  • TrailRiderXRL
Posted August 09, 2007 - 03:13 AM
Cool Thanks guys! I'll check HD then try the on line site!
  • tdamore
Posted August 09, 2007 - 03:18 AM
FYI - that online site is just a microfiche of the OE Honda parts so if you order from them you will end up with the original soft screws.
  • HawkGT
Posted August 09, 2007 - 08:27 AM
I removed every screw from by carb and took them all to Ace Hardware (or was it TrueValue?) and matched them up to allen head screws. I seem to remember needing to go to two places to find the little guys that hold the needle in the bottom of the slide. Those are really nice to have as allen heads though--a ball end allen wrench makes quick work out of what was a PITA.
  • martinfan30
Posted August 09, 2007 - 09:37 AM
i like the soft ones. with the right torque they are fine. plus i would think they are more likely to become damaged(the threads) before the holes in the carb body. as is the case with my recently replaced fuel screw that stripped out(no damage to carb/repl. with the external screw).
  • Denn10
Posted August 09, 2007 - 11:25 AM
home depot or lowes they have about the same bolts i ALWAYS replace those as the screws SUCK!!!
  • HawkGT
Posted August 09, 2007 - 11:52 AM
I've always believed they make those OEM screws so soft for the reason you mention: You'll damage the screw (philips head) before damaging the aluminum carb body by over tightening. Nonetheless, if the proper torque is used it doesn't (shouldn't?) matter what the screw is. You just have to be aware of what is "proper torque" with allen heads since they will accept a lot more torque.
I like the allen heads because they can be tightened/loosened from an angle with a ball-end allen wrench and are just generally easier to work with.
  • Denn10
Posted August 09, 2007 - 01:00 PM
never use those just cause the ball head allens do strip alot if the screw/bolt is kinda tight
  • martinfan30
Posted August 09, 2007 - 01:08 PM
well dont use chisel and hammer!lol!!:busted:
  • HawkGT
Posted August 09, 2007 - 01:30 PM
I'm pretty confident I can tell when it's appropriate to use a ball end and when it's not. ;)
  • PowerCell
Posted August 10, 2007 - 06:55 AM
http://www.mcmaster.com/
Honda XR650L 2016
  • 0 reviews
  • 17 replies
  • Hot  35 replies
Honda XR650L 2017
  • 0 reviews
  • Hot  29 replies
