06'-07' ODO Head Removal
No replies to this topic
  • SJMC_DON
Posted August 08, 2007 - 10:11 AM
So on the WR's with the digital ODO/Enduro comp, in order to remove the "cable" coming up from the front hub you have to remove the entire "head" or pickup that is effectively the RH side spacer and seal..
With old mechanical ODO's you could just un-screw the cable and cap the threaded connection point at the head.
So - I went and got a YZ spacer and new bearings and seals but the WR hub does not provide enuf recessed hub to get the seal to stay in place...
Has anyone done this succesfully with out changing to a YZ hub? And if so, how?
Thanks!:ride:
