How far down do I grind down the weld on my header I don't want the weld to break I'm not sure how far is too far?:excuseme:
Header Grinding
Started by
Benrod327
, Aug 08 2007 09:00 AM
9 replies to this topic
Posted 08 August 2007 - 09:04 AM
I ran mine down so the opening was same diameter as the pipe. On a 94 dr350.
Posted 08 August 2007 - 09:07 AM
Ditto.
Posted 08 August 2007 - 09:35 AM
Yep, basically you want a straight shot down the ID of the pipe. No humpy bumps for the exhaust gases to negotiate and cause turbulence. Just don't get too wild with the carbide grinding bit! I like using rounded end bits so there is no chance of cutting a sharp groove on the pipe interior anywhere when the weld is down close to the actual pipe ID. A sharp edge is where the pipe will want to crack. As long as you don't cut into the pipe wall thickness you will be fine. Just be cautious as you approach the actual pipe..... and, of course, don't make the flange sealing surface any narrower.
Posted 08 August 2007 - 05:24 PM
/\ Depending on what else is done to your bike, you may need to re-jet as well as adjust the fuel screw.
