Hot Start?
18 replies to this topic
  • Kaleb
Posted August 08, 2007 - 08:01 AM
Does this cable really need to be attached? I don't ever use the hot start and don't have trouble starting the bike anytime. Is this something I can pull out and plug? Get rid of one more thing on the handlebars?
Has anyone attempted this?
Thanks
  • Math
Posted August 08, 2007 - 06:09 PM
Kaleb,
What is that hot start you have on the handle bar? is this a DrD? Anyway, if you don't need the hot start, I suspect your jetting is a little poor. So instead of removing the hot start, I would suggest you get that jetting dialed up and start using the hot start...
  • Kaleb
Posted August 09, 2007 - 03:10 PM
Math, On the 2005 WR450 its the lever on the left side of the handlebar. Its supposed to be pulled in to help start when the bike is warmed up. The bike actually runs great and starts ok, even with kick starting so I don't know exactly what that is for...maybe to open up more air???
  • byggd
Posted August 09, 2007 - 03:47 PM
You hit it on the nose! It lets extra air in to help start a hot bike or after a lay down. I've only used mine a couple of times; when riding in the mountains after a challenging hill climb I shut my bike of while waiting for my buddy to make the climb and once after an unexpected get off :busted:
  • trailordune
Posted August 09, 2007 - 05:49 PM
If your bike is jetted properly you will use the hot start every time after the bike is warmed up. At least you should as it will fire up twice as fast. Sound like your pilot circuit is lean at the very least.
  • Math
Posted August 11, 2007 - 01:26 PM
I perfectly agree. Admit that the pilot is too lean, you fall in a situation where you don't have to lean the air-fuel mix to get a start even when warmed up. This is most probably what is going on...
It might be fun not to be obliged to use the hot start but the drawback is that you are too lean mostly all the time when running so the bike probably runs a little too hot and underpowered...
  • foxomatica
Posted August 12, 2007 - 12:59 AM
I dissagree. My bike is jetted perfectly and have never needed the hot start. It has long since siezed (it should be lubed periodically at the carb) and I ripped the whole system out. If you get in a situation where you need a little "hot start help" you can always choke it. The hot start does not give it more air it gives it a little blast of extra fuel. Choking is a cheater way and a little inconvienient if you are on a hill or awkward situation but it happens so rare, who cares.
Fox
  • SXP
Posted August 12, 2007 - 09:05 AM
The hot start does not give it more air it gives it a little blast of extra fuel. Fox
You couldn't be more wrong. The hot start DOES allow more air; the choke more fuel.
  • trailordune
Posted August 12, 2007 - 09:11 AM
Fox
Sounds like you have your jetting and maintenance down to a science Fox :bonk: . The hot start indeed leans out the pilot circuit for starting a warmed up bike, just opposite what the choke does.
  • byggd
Posted August 12, 2007 - 05:13 PM
He must be thinking on the accelerator pump. That’s the ONLY thing that will give an extra shot of fuel.
  • Rich_in_Orlando
Posted August 13, 2007 - 07:11 AM
Kaleb, you will be glad you have the hot start when you start riding in hot conditions. Eventually you will use it. Don't take if off.
  • Kaleb
Posted August 13, 2007 - 08:06 AM
Actually the bike was jetted with a 48 pilot and was running ragged at a steady throttle. I switched to a 45 pilot and it ran perfect so its hard for me to agree that its lean. It didn't pop on decel. Truth to tell it probably was me because I just got used to bliping the throttle when I start...maybe next time out I will hit the hot start. Is that a pull and hold our just pull and let go deal? I have only ridden the bike 2X now and am still learning about it.
thx
  • Rich_in_Orlando
Posted August 13, 2007 - 12:44 PM
The pilot jet doesn't control starting. The start jet does. Apples and oranges.
  • groffster
Posted August 13, 2007 - 01:50 PM
Yeah, if the hot start worked like the choke why would they put both on it?
  • byggd
Posted August 13, 2007 - 02:25 PM
Pilot jet or slow jet as some call it DOES affect start up. I have worked on many bikes where the pilot jet is clogged and the bike won't idle without the choke on.
  • Asgeir
Posted August 13, 2007 - 02:36 PM
I have a 45 pilot and have not had to use the hot start (it is actually siezed)
I know for a fact that I need to richen my pilot. Should be at least 48 or richer.
How does one unseize the hot start plunger ?
  • Rich_in_Orlando
Posted August 14, 2007 - 08:54 AM
You just proved my point.
Idling is running, not starting.
I do agree, however, that there is some relationship between starting and the slow circuit, but the start jet is the controlling factor in starting. After it starts, then the slow circuit takes over.
Sounds like I'm splitting hairs but I wanted to help kaleb.
  • Rich_in_Orlando
Posted August 14, 2007 - 08:59 AM
Take the carb out, get a wrench, remove the plunger, clean it, and reinstall everything.
  • byggd
Posted August 14, 2007 - 10:15 AM
Here is a link showing the relationship of each circuit and where each comes into play. Look at figure #1. I hope this helps.
http://www.thumperfaq.com/jetting.htm
