XR600 Oil Cooler Lines
10 replies to this topic
  • Galea
Posted August 08, 2007 - 01:41 AM
Hello all,
I have fitted an XR400 oil cooler to the frame of my 98 XR600. I now need the oil lines as the set-up is different from the XR400. Does anyone fabricate the oil lines? Thanks.
Regards,
Joseph
  • martinfan30
Posted August 08, 2007 - 07:06 AM
try NAPA.
  • Galea
Posted August 08, 2007 - 07:11 AM
I was thinking that maybe there is a company which can supply them ready made, just need to bolt them on .... evidently not ;-)
  • martinfan30
Posted August 08, 2007 - 07:16 AM
check XR'S ONLY.
  • cleonard
Posted August 08, 2007 - 08:57 AM
try NAPA.
Don't think he is going to find a NAPA in Malta. NAPA is a large autoparts chain in the US.
Here in the states there are shops that specialize in hoses of all types. They can custom make just about anything with a hose. Try to find one of these hose shops.
  • martinfan30
Posted August 08, 2007 - 09:22 AM
Here in the states there are shops that specialize in hoses of all types. They can custom make just about anything with a hose. Try to find one of thess hose shops.
ya guess i didnt see that!!:crazy:
  • Bennito
Posted August 08, 2007 - 10:11 AM
This thread uses about 120$ worth of fittings and high end hose.
Tubing I've seen at stores has been english. think I need to hit a hydraulic shop for metric. (need to get the female nuts for the oil cooler. I figure re-use on the 600 end.
  • Kyron
Posted August 08, 2007 - 11:21 AM
find a place that makes hydrolic lines .........
  • drtlvr
Posted August 08, 2007 - 12:48 PM
go to your local hardware store and pick up a fitting that will thread into the oil cooler and the fitting must have a 90 degree threaded hole on the side that you can thread a barbed fitting into then you slip oil cooler hose over the fitting and use a hose clamp to secure it,on the lines coming off the motor just cut them and slide the hose over them and secure with hose clamps,if you can't find metric fittings tap the oil cooler out to american pipe thread and you will be set.
no reason this set up should cost over $20.00 american,don't waste your money on expensive fittings the oil pressure is so low on those pumps you could hold the hose on with your hand.
  • nate992v
Posted August 08, 2007 - 07:27 PM
Contact Summer's Racing. Good folks. They used to have them all kitted up with the cooler. They might be able to get you some.
  • Galea
Posted August 09, 2007 - 02:04 AM
Thanks for your help guys.
  • 17 replies
Washington
  • Hot  32 replies
  • Hot  35 replies
  • 22 replies
  • Hot  60 replies
