springs?..boing!
16 replies to this topic
  • bigwake
Posted August 07, 2007 - 07:15 PM
ok i'm 255 lbs..and riding stock rear spring on my 03 yz450f..is a 5.4 enough for me?..i have a chance to buy one..and i have no idea what these numbers are..any help?
  • 642MX
Posted August 07, 2007 - 07:26 PM
A 5.4 is too soft for you. I'm 225 and use .48 springs on the front and a 5.8 on the rear.
Go over to Race Techs website and use the spring rate calculator, it will tell you exactly what you need.
  • bigwake
Posted August 07, 2007 - 07:27 PM
ya..where is the calc?i couldnt find it..
  • 642MX
Posted August 07, 2007 - 07:33 PM
Fork calculator: http://www.racetech....SpringType=Fork
Shock calculator: http://www.racetech....pringType=Shock
  • bigwake
Posted August 07, 2007 - 07:34 PM
sweet thanx!
  • 642MX
Posted August 07, 2007 - 07:37 PM
Happy to help!
  • bigwake
..well..i used it..and all it says is not available..so it did not work for me..
Posted August 07, 2007 - 09:46 PM
That link won't work because of the way the site is set up. Go to http://www.racetech.com/ , click "Dirt Bike" , then look for Spring Rates Search at the left.
Their recommendations are .50 for the front, and 5.8 at the rear.
The numbers are rates in kg/mm. in the case of the fronts, each spring requires .50 kg of applied pressure to compress 1mm. The rear requires 5.8 kg to compress it the same amount.
The fronts are so much lighter because there are two of them working together, and they act directly on the load. The rear works alone, and is at about a 3:1 disadvantage because of being mounted so far forward of the wheel.
  • PatrickM
Posted August 07, 2007 - 11:06 PM
I weight about 265 lbs and I have a 5.9 Kg rear spring on my YZ400F.
my shop guy said that anything more than that would be way too stiff and would only be used if you do lots jumping.
I hope this helps...
Patrick M.
  • bigwake
Posted August 08, 2007 - 04:32 AM
ya..that deffinately helps..i was offered a 5.4..so there's no point in me getting it if its no better than what i already have..thanx
  • Yz400Flyer
Posted August 08, 2007 - 02:17 PM
I'm a suspension noobie, and trying to learn more about that foreign world...
The site says that I need lighter springs and fork springs cause I am failry light (99 400)
If the springs are too stiff what will happen to the handling (rougher ride most likely?)
And if they are too soft, do you just bottom out easier?
Is there more to it?
A
  • 642MX
Posted August 08, 2007 - 02:37 PM
A
There is more to it, but I'm not an expert on the subject. The correct springs help the bike track smoothly, corner properly and be able to handle jumps. Too light of a spring, and the bike will be riding down to far in the suspension stroke and you won't be taking full advantage of the valving. And its just the opposite if you have too much spring.
  • moto2000
Posted August 08, 2007 - 04:55 PM
When I go to the spring calculator, all it says is "ouch"...
......is it trying to tell me something?
:lol:
  • Yz400Flyer
Posted August 08, 2007 - 05:17 PM
:lol:
It is saying, get off the Wisconsin cheese and Milwaukee's "Beast"! LoL
  • Quack
Posted August 08, 2007 - 05:28 PM
I got the same rating for my springs, I think I should get off the cheese and the Miller myself at this point...... no, why take the fun out of it?
  • matts06yzf
Posted August 09, 2007 - 05:05 AM
I am 6'4 250 and to get correct sag etc with gear on, I am 6.2 on rear I ride all Mx and supercross. If you are doing alot of jumping a 5.8 will be to soft also. Look on mxtech.com or call enzo etc. Enzo wanted me at 6.4 which sometimes I feel would have been better for me
  • bigwake
Posted August 09, 2007 - 06:30 AM
i am doing zero jumps..only hitting bumps when i ride
  • Hot  30 replies
  • Hot  50 replies
  • Hot  47 replies
  • Hot  38 replies
