How do I remove the WR450's mid right plastic opposite the air filter?
7 replies to this topic
  • Nostalgic
Posted August 07, 2007 - 08:15 AM
Searched here for an hour and can't find the answer.
I need to remove the plastic that is on the mid/back right of my wr450.
It's the black plastic covering on the right (opposite the air filter cover that's on the left side.)
There seems to be two little deepset holes that may have some sort of hex screws or something in there. I can't see in there and have no idea how to remove this.
Anyone know what I mean?
Thanks.
  • byggd
Posted August 07, 2007 - 08:29 AM
If I remember correctly that is not a cover, it's the airbox :excuseme:
  • Nostalgic
Posted August 07, 2007 - 08:31 AM
That makes sense. I was going to remove it to take the old sticker off, clean it, and apply a new decal. Guess that one could stay on and I'll do all of that with it on the bike...
  • byggd
Posted August 07, 2007 - 12:54 PM
My 02 doesn't have a removable cover for the air box so I applied both left and right decals while on the bike. It's not too hard, just take your time and use a heat gun to help at the edges. :ride:
  • Nostalgic
Posted August 07, 2007 - 04:58 PM
Will a hair dryer work?
  • dsalvetti
Posted August 07, 2007 - 08:11 PM
My '06 has two Phillips head screws on the back edge. Once those are removed, pull outward on the rear edge slightly then slide the whole cover toward the front to clear the two posts on the front edge.
The airbox is behind that cover.
Not sure if earlier models are the same.
~Dave
  • byggd
Posted August 08, 2007 - 03:50 AM
I've never used one but others in here have they said it works fine, just takes a little longer.
  • Motoequip
Posted August 08, 2007 - 01:12 PM
I just looked at my 05 wr450 and it also has 2 phillip screws then it comes right off...
