help!!!!!!!!!
17 replies to this topic
  • nolzey
Posted August 06, 2007 - 08:48 PM
im am rebuilding my yz400f 99 and im up 2 the timming chain ( this is my first bike motor) how presice are the timing marks. with the bottom lined up to the i mark i can see both dots on the exhaust cam and 1 on the intake but it is only out by a flyshit (1 to 2mm) and it would be perfect. could the timing chain be a little streached? i know i should have put in a new one but i didnt. when i set the cams up perfect the i mark is out about 2 to 3mm off. or is that 1 tooth out on the bottom?
  • tnl
Posted August 06, 2007 - 08:59 PM
Do a search on that if you already haven't. There are alot of posts on that topic.
Posted August 06, 2007 - 10:05 PM
The question is, if you moved the cam one tooth in either direction, would it be closer, or farther from lining up?
The timing marks will rarely line up perfectly because the length of the chain exaggerates the smallest amount of wear (stretch). If moving it won't improve it, it's lined up right.
  • nolzey
Posted August 06, 2007 - 11:32 PM
thanks i realised that if i moved it anyway it would be out alot more. i should have put a new chain in !!!!!!!!!!! ill lern the hard way.
  • King_Air
Posted August 07, 2007 - 04:49 AM
If you are still in the cam chain timing change it is not too late to change it. You would only have the pull the left side (mag) cover, and on chain guide (if I recall correctly). Chain is only around $30.00.
Posted August 07, 2007 - 06:10 AM
With no intent of discouraging anyone, the flywheel and stator plate must also be removed. Easy job, none the less.
  • mkporn
Posted August 07, 2007 - 06:48 AM
With the right tool...... idealy a impact screwdriver and a torx bit that fits.
  • Wiz636
Posted August 07, 2007 - 07:50 AM
Change the chain while you're there!
  • King_Air
Posted August 07, 2007 - 08:17 AM
True that! I guess I was in a hurry while typing. Thanks for keeping us on track Gray.
  • tnl
Posted August 07, 2007 - 08:32 AM
Flywheel puller too. Do it now if it's already opened up.
  • nolzey
Posted March 17, 2008 - 12:53 AM
well i havent changed the timing chain yet but i think i need to:foul: there is a ticking noise in the top end now, well it was always there but getting worse. when the head was machined they did the cylinder as well so i lost a couple thou and fitted the hi comp piston and i think with the streach in the timing chain is causing the valve to just hit the top of the piston:cry: . i have 1 value that keeps needing adjusting as well, could this be the 1 hittin the piston? should i start wif the chain?
  • USED YZ426F
Posted March 17, 2008 - 04:26 AM
Definitely replace the chain. After all of the work and $$ you put in to the head, not replacing a $30 part can potentially cost you hundreds more.
Which valve is always needing to be reshimmed? And is it the same valve everytime you check them?
  • nolzey
Posted March 17, 2008 - 11:56 PM
yer ill do the chain shortly. yer its the same valve all the time the kick side intake valve. the machinest said the seats were really bad and i dont know how deap he took the seat down to seal it. maybe its gone sort too. ive got around 145 shims in all the buckets except the problem valve which has a 125 in it.
  • USED YZ426F
Posted March 18, 2008 - 03:48 AM
If there is just that one valve that needs to be reshimmed every few hours, then you definitely have a problem with it.
Did the '99s use stainless steel valves? If so, I'd consider replacing that valve, or at least having the head looked at by another shop.
  • nolzey
Posted March 19, 2008 - 01:15 AM
yer stainless in the 99, i might pull it down again and get new valves and seats and chain. any idea if i can use titanium valves out of a 426?
  • USED YZ426F
Posted March 19, 2008 - 05:49 AM
Not sure, but why would you want to?
The SS valves tend to last longer from what I've read here.
Once the ti valves wear through the very thin layer of hardness, they wear considerably faster than the SS valves.
  • sirthumpalot
Posted March 19, 2008 - 05:54 AM
Reassembly tip: Get some soft clay and put some small pieces on the piston just under the valves. Fully assemble the head (including chain) and turn it over carefully a few times. Remove the head and check out the clay pieces carefully. That will tell you if the valves and piston are making any contact. With all OEM parts there's no real reason to believe that parts would be making contact, assuming it's assembled correctly, but if you start buying parts ala-carte then this can help save you some serious cash. Good luck!
  • nolzey
Posted March 20, 2008 - 12:34 AM
ill do that, tnx.i wanna be sure this time or ill buy factory parts
  • Hot  30 replies
  • Hot  113 replies
  • 0 replies
  • Hot  38 replies
