Spark arrester 2005 wr450
10 replies to this topic
  • knucklehead
Posted August 06, 2007 - 02:13 PM
looking to pick a spark arrester for my 2005 wr 450 - any suggestion? i found one from the Yamaha web site but was hoping to find something else.
thanks.
  • JSanfilippo
Posted August 06, 2007 - 03:01 PM
The stock pipe already has a spark arrestor :prof:
Are you talking about a completely new muffler?
  • knucklehead
Posted August 06, 2007 - 03:13 PM
no - i just need a spark arrester for an enduro. i remember taking the baffle out of the muffler but not the spark arrester - i dont remember seeing on either.
  • jim-in-so-ore
Posted August 06, 2007 - 04:19 PM
Take the end cap back off, then remove the 4 allen bolts that hold the exhaust pipe to the muffler body. Behind that should be the screen type spark arrestor.
Jim
  • GCannon
Posted August 06, 2007 - 09:07 PM
I just got a new Q2 Love it!
  • knucklehead
Posted August 07, 2007 - 05:32 PM
Jim
i was working on this and stripped one of the allen bolts!!!
i'll look at the Q2 - for stock exhaust?
  • Bleeds_Blue
Posted August 08, 2007 - 03:11 PM
If you have a factory exhaust and didn't remove the screen, you should still have the spark arrestor. Try vise-grips or take a die grinder(cut-off wheel)and cut into the head creating a slot for a flat head screwdriver. :ride:
  • eissinger4
Posted August 10, 2007 - 07:55 AM
I have a stock 05 YZF exhaust on my 06 WR450. I went down to my local John Deere dealer and bought a spark arrestor for an 06 J.D. Gator. Same size, and passed inspection. Not sure if your pipe is the same, but this is a good idea that might work for you. BTW, it was only $8....
  • knucklehead
Posted August 10, 2007 - 03:30 PM
great idea - i'll try it.
thanks.
  • MountainMax
Posted August 12, 2007 - 11:08 AM
I have a stock arrester i took out of my 06wr450 you can have that one if you like.
  • TWILES
Posted August 12, 2007 - 11:29 AM
I stripped two of the allen bolts out. I just drilled the heads off and worked studs out with a straight screwdriver.
