please help! Jetting!!! AUGH!!!!
10 replies to this topic
  • Guest_Guest_*
Posted August 02, 2000 - 04:20 PM
This probley isnt going to problem for 99% of the people on this board, but I must fall into the other 1%. Ok, Im a novice at jetting and Im antsy to figure this out so I hope someone posts fast to this:
The question is:
Im trying to change the position on my needle and I found the needle :) WOO HOO!
Now....after taking the allen screw out that covers the needle, how do I get the needle out? (I feel like quite the imbasol here)
Darin from Missouri 1999 WR400F
  • Henry
Posted August 02, 2000 - 04:29 PM
Hey Milkman,
just put it upside down! :)
'98 WR400F, YZ timed, main:180, pilot:48, DVR needle 4th clip from top,
snorkel removed, YZ tank/seat combo, YZ front no.plate/rear fender,
DSP Ti exhaust system, Brembo front brake,steel braided hose, EZ clutch adjust perch,
Stroker billet rear brake reservoir
  • Clark_Mason
Posted August 02, 2000 - 04:42 PM
If the carb is still in the bike I use very thin jawed needle nose plyers.
Clark
  • Guest_Guest_*
Posted August 02, 2000 - 05:03 PM
Thats why.... you the man CLARK!!!
I think I hit the panic button a little early on that one.
  • Mitch_from_Oz
Posted August 02, 2000 - 05:55 PM
Hey Milkman.
Dont worry champ, I know the basics like how to change the wheels, clean the airfilter, oil, suspension and that is it... I even need help putting gas in as I always spill the shite everywhere.
Mitch
  • Guest_Guest_*
Posted August 02, 2000 - 06:13 PM
Thats why I love this forum. Its people helping people. Heart warming! :)
  • Henry
Posted August 02, 2000 - 08:45 PM
Hey Mitch, I need people to help me pour in the gas! :)
Do you have a solution for this?? :D
Me too! pour my gas all over the tank while refilling.
  • Kevin_in_New_Hampshire
Posted August 03, 2000 - 12:15 AM
Hey Milky,
Is that how you spell imbasol? I was going to use it once on here and decided against it since I didn't know how to spell it. Milky YOU ARE a trend setter!!
  • AngryCandy
Posted August 03, 2000 - 04:48 AM
imbecile
I should know. I have been called one many a time!
  • Guest_Guest_*
Posted August 03, 2000 - 07:29 AM
I just spell'em like they sound and hope everyone knows what Im talking about! :)
  • Guest_Guest_*
Posted August 06, 2000 - 08:58 AM
I remove the air boot to be able to put my finger inside, twist the throttle at full position, grab the needle fron the inside and release the throttle. In that way the slider goes down but the needle head stays in the upper position. I have anyway to remove the air rubber boot to twist the carb. Really simple.
