foam filter oil help
5 replies to this topic
  • IMNXNYR
Posted August 05, 2007 - 01:54 AM
Any recommendations on a foam air filter oil that won't drip off the filter when exposed to high temperatures? I'm currently using PJ1 on the UNI and squeezed as much as I could out of the filter but I'm still getting the occasional dripping off the foam into the air box. Not a big deal other than while it's resting on the kickstand the oil tends to accumulate in the side panel. There's gotta be a better choice out there.
  • mitown
Posted August 05, 2007 - 02:18 AM
I always let the oil dry first
  • creeky
Posted August 05, 2007 - 03:07 AM
Me too, if I have the time, I hang the filter on a hook with a container under it and let it drip off the excess.
  • philipstjohn
Posted August 05, 2007 - 03:28 AM
Remember, you want complete saturation, but not dripping oil when your done oiling the filter. Once I know the filter is completely oiled through, I pat any excess oil slightly with a clean towel. I have never have any excess oil issues like you mentioned, and I have been using UNI oil lately. If you are not using a spray on oil, this may help you not to over oil...:thumbsup:
  • BWB63
Posted August 05, 2007 - 01:04 PM
I do sqeeze out some...you kinda have to but, I want as much oil in the filter as it will hold, it is the protection. I use the most sticky, water proof, nasty, hard to clean out oil I could find and for me it is the quart Golden Spectro blue sticky goo. A lot like the Bell Ray in the White quart bottle just a lot thicker and much stringier. If I am in a hurry I have put as much as I can in the filter squeese a little out and not let it dry all the way and it will drip a little out of the side pannel....chain lube:goofy:
I have many UNI air filters for the bike but, they are not always ready, I clean and oil after every big ride or weeken ride.
  • martinfan30
Posted August 05, 2007 - 01:08 PM
thats killin 2 birds with 1 stone(the chain lube)! i like the honda pro oil and cleaner. works well on my pod filter. dont get any drips.
  • Hot  60 replies
Honda XR650L 2016
  • 0 reviews
  • 22 replies
  • 9 replies
