any 98 slide solution?
2 replies to this topic
  • Henry
Posted August 01, 2000 - 11:28 PM
Hi fellow 98 model owner, this is the 3rd time I replaced my carby slide :)
It is a expensive part which really make me
feel uncomfortable. :D
Anyone with a solution which can solve it once and for all??
I know change to a newer carby will solve the problem, but it is more expensive?
Or anyone of you can fabricate the slide with
other type of material?? :D
'98 WR400F, YZ timed, main:180, pilot:48, DVR needle 4th clip from top,
snorkel removed, YZ tank/seat combo, YZ front no.plate/rear fender,
DSP Ti exhaust system, Brembo front brake,steel braided hose, EZ clutch adjust perch,
Stroker billet rear brake reservoir
  • Matt_Porritt
Posted August 01, 2000 - 11:45 PM
Hmmm... replaced due to cracking or wear??
Disintergration??
I know the 98 WRs had probs with the slides cracking on them.. a few went through the motor.. (for those who don't know.. thats BAD!) :)
**Ride it like you Stole it!**
Matt Porritt
99 YZ400F
Vist the Rubber Chicken Racing Online Shop
Discounts for ThumperTalk members.
  • Henry
Posted August 02, 2000 - 04:34 PM
Guys, I got an ideal, let's hear what your comments.
I'm thinking maybe I could use those metal poxy which is used to fix the rad problem,
to re-enforce the cracked line .
After hardening, use a hand file to smoothen the edges. Do you think the petrol vapour will soften the poxy? :)
Guys,what do you think, anyone in chemical engineering?
