'01 CR250 idle adjustment help
4 replies to this topic
  • mboule
Posted August 04, 2007 - 01:06 AM
Just got a 2001 CR250 and didn't get a manual with it. It starts easy and runs but won't idle, even after it's warmed up. The only adjustment screw I see on the carb is a small screw with a locknut. I tried backing out this screw but it didnt' seem to change anything. Any ideas?
  • alex211
Posted August 05, 2007 - 08:42 AM
There should be a Idle screw on the carb. Also when you find it turn it in until the bike idles.
  • skipn8r
Posted August 05, 2007 - 08:43 AM
(Assuming your carb is properly jetted to begin with...) The Mikuni idle adjustment screw has a lock nut - that's the one you found. To increase the idle speed, loosen the lock nut and turn the screw in. You may also need to adjust the air screw which is located just below and to the rear of the fuel inlet port.
  • mboule
Posted August 05, 2007 - 12:45 PM
Thanks for the info, skipn8r. I'll check it out. BTW, the manaul has been ordered.
  • mboule
Posted August 10, 2007 - 03:15 PM
I screww in that screw a few turns and it idles like a champ. Thanks again, skipn8r. Thumpertalk rocks!
New to me 02 cr250 by brassfield715
Dirt Bike   Make / Model Specific   Honda   Honda 2-Stroke
  • Hot  24 replies
Backyard Motocross Track by Will I Am
  • 6 replies
250 2 stroke vs 125 2 stroke by pnitro4
  • Hot  63 replies
Shorty Silencer? by Will I Am
  • 4 replies
FMF Shorty or Turbincore 2? by Will I Am
  • 2 replies
