fcr on a 650r?
7 replies to this topic
  • rulingtheroost
Posted August 03, 2007 - 03:40 PM
my buddy just bought a used 00' xr650r.looks to be all stock was wondering if any body has tried running a fcr carb on there bike,saw the edelbroc thing.if so hows she run?
  • martinfan30
Posted August 03, 2007 - 04:35 PM
i dont have an R, but i do run a fcr 41 pumper on my 05 650L. i love it. the throttle response is instant, jetting is easy, not to mention have an accelerator pump now. just 1 twist of the throttle it starts and idles good. great power all the way up. power wasnt a huge leap, but it is noticeable. a little more intake noise too. i know a lot of R guys like the EDELBROCK, i dont have any experience with it though. i hear its a little work to get top end balance with low end response, but that is all heresay.
  • ogrider650
Posted August 03, 2007 - 08:15 PM
i have the eddie on an 04 and i love it throttle response is amazing and no flooding this things runs all the time no matter what. never tried an FCR but the eddie get two thumbs up
  • martinfan30
Posted August 03, 2007 - 08:25 PM
curious about the eddy, you say thr. response is amazing. do you have any issues with top WOT from 3/4 to 4/4 throttle as far as a hesitation?
  • eastreich
Posted August 05, 2007 - 03:35 PM
I have the FCR41 kit from Sudco on my bastardized 650R. It is not a bolt on, as Sudco says :banghead: , as I have had to do some other modifications to make it fit well. As for the performance, it is waaaay better than the stock round slide.
If you don't mind a little fabrication, I would just but the complete carb from a Honda dealer (CRF450R part). You may have to machine the bells a little bit going that route, but I have had to change enough other stuff that it would seem easier. Also, the Sudco carb doesn't use the same pilot jets as a regular dirt FCR (the pilots are the same as the Keihin CV carbs), but the mains are the same. The Sudco 41 also has some fitment issues that a dirt FCR from a CRF, YZF, etc. will not have with the cam chain tensioner.
Was it worth it in the long run? Absolutely! Is it better than the Edelbrock? IMO, yes. The FCR is the closest thing that you can get to fuel injection. Once I got the FCR jetted right, I have never had to adjust it (I can see elevation changes of 5000 feet in a ride). The only thing to remember is that with the FCR41 that I have, is that there is no choke circuit. When the bike is cold, I give the bike three quick blips of the throttle (to 'prime' the motor using the accelerator pump), do the drill, and she almost always fires on the first kick. You then just need to run the throttle manually for a few seconds until the bike will idle on its own.
For jetting, I am running a 45 pilot, 188 main, fuel screw 1.5 turns out, needle 2nd position from the top, 100 octane fuel.
  • motoboy1968
Posted September 16, 2007 - 07:15 PM
I have an fcr from a crf450 I want to put on the 650, can i ask what needle you are using
  • porterdog
Posted September 18, 2007 - 04:31 AM
I have the FCR41 kit from Sudco on my bastardized 650R. It is not a bolt on, as Sudco says :thumbsup: , as I have had to do some other modifications to make it fit well.
eastreich, I've read that before. Can you go into a little more detail regarding what's involved? I'm not shy about giving stuff a go, but I'd like to know in advance what the deal will be...
Thanks!
  • roadrunner81
Posted September 18, 2007 - 02:48 PM
I had to cut down timing chain tesioner and use a bolt from a 450, other than that I don't recall any other real mods. almost forgot that I had to heat up tank with a heat gun and push in slighty where throttle shaft is on carb and tilt cab slightly towards frame. Runs great and would not even consider an edelbrock.
  • Hot  29 replies
Honda XR650L 2017
  • 0 reviews
  • 17 replies
  • 9 replies
  • Hot  35 replies
