Aluminum frame cleaning
27 replies to this topic
  • runester
Posted August 02, 2007 - 09:13 AM
Hey all
Somehow my frame has gotten what looks to be a water stain running down the right side of the frame in front of the airbox ...I dont think thats what it is but thats what it looks like, I dont really use chemicals to clean it but if/when I do I get em off quick and dont wash it in the sun, is there any type of metal/aluminum cleaner out there that will clean this?
Thanks!
Rune
  • mmbasa
Posted August 02, 2007 - 09:26 AM
WD40 and a scotchbrite
  • runester
Posted August 02, 2007 - 09:34 AM
Thanks, but wont a scotchbrite scuff it up?
  • mmbasa
Posted August 02, 2007 - 09:56 AM
  • Justin89
Posted August 02, 2007 - 10:49 AM
No they wont, I use those and sometimes and SOS pad for the boot marks on the frame and it dosent scratch anything up at all.
  • bigwake
Posted August 02, 2007 - 04:49 PM
try a product from wal mart..its called scratch out..i use it allllllll the time on my cars and frame..whenever you have a scratch that hasn't removed to the paint..use it! this stuff is amazing!! my car gets berry stains from a tree..and this stuff takes it out like nothing! its bascially a car wax...but it works miracles! try it on your frame and see if it goes away..
  • tommyj
Posted August 02, 2007 - 05:49 PM
Simple green and 0000 (super fine) steel wool works awesome!!!
  • bigwake
Posted August 02, 2007 - 05:59 PM
o yes! i can deffinately vouch for that combo! i use it allll the time!!
  • cowboyona426
Posted August 02, 2007 - 06:25 PM
0000 steel wool? :eek: I've been using the 00 and had good results myself. A scotchbrite sponge and some metal polish also helps (blue magic), I've also used orange glo hand cleaner on a scotch brite pad. I'd like to go nuts on the frame and sand it down smooth this winter- I HATE that textured finish!
  • tommyj
Posted August 02, 2007 - 06:31 PM
i just went with 0000 cause i didn't want to scratch the frame. it works so i just stuck with it.
  • runester
Posted August 02, 2007 - 10:15 PM
Right on,
Thanks for all the replies...
I think I'll try the steel wool, I have loads of it in my garage for cleaning gasket material off engines, I also think I'll pick some of that stuff from walmart, I got the berry tree out front...drives me F...ing NUTS!!!!!!!!!!!!!!!
It is dropping like a thousand a day right now, Thanks to everyone,
Rune
  • bigwake
Posted August 03, 2007 - 07:19 AM
ya..i forgot to mention..the scratch out is in a little yellow bottle
  • Polar_Bus
Posted August 03, 2007 - 09:49 AM
another vote for WD40 and a fine scotch brite pad..... makes your frame look new again.
  • treygreen
Posted August 03, 2007 - 10:18 AM
I used multiple grades of sandpaper and then some mothers aluminum polish. Bling Bling. It does scratch easily again but it will only take 5 mins to buff her back to a shiny mirror like finish. Went to the track two weeks ago and got a lot of compliments.
  • Darvo
Posted August 03, 2007 - 10:23 AM
I use wd-40 and a rough steel wool. I don't like the look of polished frames, so I try to keep the texture to mine for the dull aluminum look.
It just depends on what you like.
  • Red Falcon
Posted August 03, 2007 - 11:12 AM
I use the Scotch Brite maroon pad (recommended in the manual for Honda CRF's. I've used it and it works well.
  • Ga426owner
Posted August 03, 2007 - 11:14 AM
I like the dirty look......so no frame cleaning for me:p :p
  • JSanfilippo
Posted August 03, 2007 - 06:52 PM
I think the water stain is from letting the water sit on the frame too long. When I wash my WR I spray it down with simple green, hose it off and then blow the water off with a shop vac. No water stains even washing it in direct sunlight :thumbsup:
  • Polar_Bus
Posted August 04, 2007 - 04:51 AM
Yea, it's fun to pull into the pits with a dirty bike, and just spout off BS like "I just came from Budds Creek racing in the AMA pro-am-vet national series" The gullable young kids fall for it every time.... and then all of a sudden you're GOD in the pits.....
  • Ga426owner
Posted August 04, 2007 - 05:04 AM
amen:thumbsup:
  • Hot  50 replies
  • Hot  36 replies
  • 0 replies
