A jetting question 4 Mr Dean
2 replies to this topic
  • Guest_Guest_*
Posted July 21, 2000 - 02:59 AM
Hi James,
I have bought a EKP needle and was wondering about jetting?
My bike is as follows:
98'WR YZ timed,
air box lid removed,
de-oct'ed,
CRD exhaust (approx 41hp @ 92-3dbls)
mainly sea level in England (so cold air most of the time) at present i run a DVP needle, 48 pilot, 175-180 main, 2 turns on pilot screw
The present set-up works great (thanks Clark) but after reading your post on the EKP needle, i got excited as i ride mainly woods and more boost in the mid power range sounds great. Any help much appreciated. Thanx
  • James_Dean
Posted July 21, 2000 - 06:09 PM
Ben,
Try the EKP needle in the 3rd clip with a #165 to #170 main. The exhaust looks to be quiet at 92-3dbls, is this very restrictive? Were you using clip #3 or #4 with the DVP? Your results would be helpful. I'll try to keep track of all the feedback.
James Dean
[This message has been edited by James Dean (edited 07-21-2000).]
  • Guest_Guest_*
Posted July 24, 2000 - 12:37 AM
Hi James
I tried the EKP needle this weekend with a 172 main ( i had the jet already) there was most definitly an increase in the mid range, pulling a higher gear seemed alot less work for the bike 'more torque great'...I've ordered a 170 main aswell so i'll try it next weekend at a hair & hounds race.
As for the exhaust, well I guess it doesn't flow as much as DSP, Biggun etc, but here in England they are very strick on soundlevels (94dbls), the CRD unit is a french exhaust designed for the YZ/WR and improves power over the WR without baffle. crd-international.com
they also do a titanium SX tapered system which only puts out 98dbls.
As for the DVP needle i had it on the 4th clip.
James thanks for all your pearls of carb' wisdom.
