chain question
5 replies to this topic
  • blue_rider
Posted August 02, 2007 - 08:10 AM
I know it's been asked, but I can't seem to find the size of chain I will need for my 2000 YZ426F. I know it's 520, but if I want to up the sprocket in the rear a bit (say to a 50t) what length do I need?
  • ben_suhard
Posted August 02, 2007 - 08:24 AM
How many links does your old chain have? I don't know about the other brand chains, but the DID chains come in 112 and 120 links. With the 120, you take off what you don't need. The 120 link costs a little more.
  • blue_rider
Posted August 02, 2007 - 08:47 AM
I can't go off my old chain because I converted the bike to supermoto a few years ago. I'm trying to build up a dirt set-up now to be able to switch back and forth. IIRC stock length is 114 links, but I can't remember stock gearing (high 40's and I believe a 14 CS, but I just can't remember).
  • flintlock28
Posted August 02, 2007 - 10:08 AM
Yes, a number of chains come with 120 links.
For my 04' yz450f with stock gearing, I think it uses 114 links (14 teeth up front 48 for the rear)....I think 120 links would be plenty for what you want to do.
  • King_Air
Posted August 02, 2007 - 10:15 AM
Stock gearing on 2000 426 is 14T/49T. I use a 114 link Reginia with stock gearing.
  • 00YZ426FMRCD
Posted August 02, 2007 - 10:24 AM
King Air is correct. Just a note to add. I run a 50T rear. a 116 link will work fine with the 50T and you shouldn't ever have to add or remove links.
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
  • 0 replies
  • Hot  36 replies
Help with 2000 yz426 by weekend woods racer
  • Hot  36 replies
