spark arrester
16 replies to this topic
  • mongo_00
Posted July 31, 2007 - 03:20 PM
I have a 07 yzf450 and a 05 yz250 and was wondering if anyone out there has a simple cheap way to add a spark arrester. 07 has a stock pipe and 05 has a pro circuit silencer. My issue is that I am trying to go on a trip in a area that requires this and probably will not go for another good while. What can I do?
  • 06crf_er
Posted July 31, 2007 - 03:22 PM
www.promotobillet.com
Simple, but not super cheap. Cheaper than buying a pipe though.
  • ThompsonV311
Posted July 31, 2007 - 05:01 PM
This will take care of the 07, and save a few bucks too. Promotobillet s/a with silent insert. http://www.thumperta...ct=27676&cat=32
  • Ganadore
Posted July 31, 2007 - 06:31 PM
Yep, I couldn't be happier with mine.
  • treygreen
Posted August 01, 2007 - 03:25 AM
^^^^^ X2
  • YZSandMan
Posted August 08, 2007 - 09:52 AM
Hey Ganadore, your graphics look awesome. Where did you get them?
  • WB450
Posted August 08, 2007 - 01:53 PM
Same here regarding the PMB.
  • WB450
Posted August 08, 2007 - 01:54 PM
What tank is that?
  • Ganadore
Posted August 08, 2007 - 06:00 PM
What tank is that?
The tank is a black 3.1 gallon IMS. Ganadore
  • Ganadore
Posted August 08, 2007 - 06:04 PM
I got the graphics directly from Yamaha in Europe and had them shipped over. I really liked the Doug H retro kit but I wanted something different than everyone else and I came across those. Ganadore
  • bg10459
Posted August 09, 2007 - 05:28 AM
The DRD SA endcap is basically the same thing as the PMB endcap, but it's less expensive. DRD lists the endcap for $80 and the quiet insert for $40. The PMB endcap lists for $125 and sells for $113 in the TT store. I got my DRD endcap off ebay for $60 shipped to my door.
http://www.dubachrac...bachRacing.html
  • WB450
Posted August 09, 2007 - 07:54 AM
How far do you think you can go on a tank now?
  • tnl
Posted August 09, 2007 - 07:56 AM
The DRD SA endcap is basically the same thing as the PMB endcap, but it's less expensive. http://www.dubachrac...bachRacing.html
Not really! The PMB has color options. The DR.D doesn't. That's the difference. For an extra $40 or so you get the bling with the PMB.
Posted August 09, 2007 - 07:58 AM
If you buy the exhaust from Dr.D with the SA kit in place, it's much less expensive ($15-20), and the screen is easy to remove when not needed. I believe the metal can models are available this way.
  • bg10459
Posted August 09, 2007 - 08:51 AM
Aha:prof: . Bling. :thumbsup:
  • Ganadore
Posted August 09, 2007 - 04:34 PM
Approximately 72.2% farther than on a stock tank :smirk: .
Seriously, that's all going to depend on the rider and the ride. The IMS tank holds about 3.1 gallons compare to the stock tank I believe is 1.8.
  • tnl
Posted August 09, 2007 - 08:01 PM
I just installed the IMS on mine and got 1 ride on it so far with 70 miles round trip in 2nd and 3rd gear trails and tank showed half full??
  • 9 replies
  • Hot  47 replies
  • 10 replies
