What forks will fit?
7 replies to this topic
  • Quack
Posted July 30, 2007 - 05:59 PM
I have a 2003 YZ450F and the left side fork has two dings in the tube. So I am looking to find out what years and models will make a direct replacement, or what I have to do to make a different models forks work.
Thanks for the help
  • ThumperKid250F
Posted July 30, 2007 - 06:06 PM
Thanks for the help
well you wouldent want to have a 2004 fork on 1 side then a 2003 fork on the other side that wouldent make sense since in 2004 it got better suspension.
but neather way i dont think any newer years would fit but im not sure. try calling up your yamaha dealer and have them look up the part #
  • KJ790
Posted July 30, 2007 - 06:50 PM
If you're not going to get a 2003 fork you would have to get a pair of forks. Whatever you get they will have to be from a bike either 2003 or older. In 2004 the forks were made larger diameter, so if you got a pair of newer forks you would have to get new triple clamps to fit them.
  • Quack
Posted July 30, 2007 - 06:53 PM
So 03 back to when? What models, I am thinking the best is to replace as a pair. I have been watching ebay, but am not sure which ones I could get.
  • 642MX
Posted July 30, 2007 - 07:11 PM
I believe that 98 to 03 they where all 46mm forks. 04 and up are 48mm. The valving is different from year to year also.
Posted July 30, 2007 - 07:14 PM
The only ones that will directly fit and have the correct valving and springs are those from an '03 YZ450. You could use the fork tube assemblies from any '01-'03 YZ/YZF and as far as fitting on the bike they would. As far as working right, they'd need to be re-sprung and revalved.
I have a set of '04 forks on mine, using '04 clamps, of course. You could also use '05's, again with the right clamp set, and your wheel, etc., would still fit.
  • Quack
Posted July 30, 2007 - 10:59 PM
Thanks Gray, that is what I was wondering. I could just take the guts out of mine and reuse them in the other forks, correct? Or I can get a complete front end for a newer year and switch it out completely?
Posted July 31, 2007 - 08:34 AM
I am not certain about the interchangeability of the internals of the '01-'03 forks. The springs will interchange, though. The '04 and '05 forks are each two unique issues, and can't be mixed with parts from other forks.
  • 10 replies
  • Hot  36 replies
  • Hot  113 replies
  • Hot  50 replies
