Clark - Advice please
4 replies to this topic
  • Mitch_from_Oz
Posted July 09, 2000 - 09:17 PM
Hey Sir Carby.... :)
My Current setting are:
WR Needle - position 3/4
MJ - 180
PJ - 48
2.25 turns out.
fuel - 96oct
I was at the track on Friday. Cold, a little moist. The bike would seem to cough/choke a little on the power in low/mid. Altitude is about 1500 feet I am guessing.
Here is what I propose and let me know if it makes sense:
YZ Needle - position 4 (5JG-14916-EP)
MJ - 180
PJ - 48
2.25 turns out.
fuel - 96oct
Thanks Mate
Mitch
  • Mitch_from_Oz
Posted July 09, 2000 - 09:19 PM
Oh, Clark, dont forget, the toilet flush and susequent rotation goes the other way... :)
  • Clark_Mason
Posted July 10, 2000 - 07:10 PM
Mitch
I assume you are YZ timed. The jetting you suggest should be in the ball park. My only suggestions would be to try 1) a 50 PJ at 1.25 tirns on the fuel screw, and or 2) turning the TPS sensor about 2mm clockwise.
Clark
[This message has been edited by Clark Mason (edited 07-10-2000).]
  • James_Dean
Posted July 12, 2000 - 01:11 PM
Mitch and Clark,
The #180 main jet is too big for a first attempt. The YZ426 needle 5JG-14916-EP will open up the nozzle passage above the main jet by 20% at full throttle. The main jet needs to be reduced when switching to this needle. The YZ went from a #175 main to a #165 between '99 and '00 as this change was made.
-Suggest that you try #170-#175 main.
James Dean
  • Clark_Mason
Posted July 12, 2000 - 01:22 PM
Mitch If you are running a "E" series needle with the steeper taper it will come on the main jet faster and require less main--I concur with James on the Main jet you will most likly end up between a 165 to a 175.
Clark
