the "REV BOX"
10 replies to this topic
  • ZEHR
Posted July 28, 2007 - 06:20 AM
Hi i was just wondering if anyone has heard of the "rev box" i saw it on ebay for about $100.00 and sounds like it does the same thing as a vortex, just not ajustable? also it says it's for yz models for 03-06 would it work on a 04 wr? thanks.
  • Mutu
Posted July 28, 2007 - 08:49 AM
I would be wary of outlaying cash on something unknown like that.
I know it is an ignition, but what brand? There is heaps out there.
I believe the one you are talking about would work on your bike.
A good plug and play ignition for '03 - '06 WR's is the OEM '03 YZ450F ignition. It is nice and aggressive and you should be able to find one pretty cheap.
I have a vortex ignition on my bike, they do make a noticable difference.
  • ZEHR
Posted July 28, 2007 - 01:19 PM
thanks, so if i buy the 03 yzf box will it up hp, even if i already cut the grey wire? ps i will be putting in the ex cam from a 04 yz
  • Mutu
Posted July 29, 2007 - 05:50 AM
The benefit of YZ ignitions is that the curve is more aggressive and has a higher rpm limit. The '03 in particular was the most aggressive. There is a performance gain, but not that much in terms of hp. Not even with the vortex ignition which is like 1-2hp.
A '03 YZ ignition is just an idea, as they should be quite cheap to pick up from the wreckers or off ebay. :ride:
  • ZEHR
Posted July 29, 2007 - 06:53 AM
ok thanks alot for the info, i think i'am going to try that then!
  • ZEHR
Posted July 29, 2007 - 12:16 PM
I've done a bit of reading and i was wondering if i would have to change my flywheel or will any of the yz 03-06 cdi's work? just plug and play or is there more to it? thanks
  • Mutu
Posted July 29, 2007 - 12:49 PM
plug and play!
  • Thermos O flask
Posted July 30, 2007 - 02:20 AM
Hi,Do you know if that applies to the '00YZ also? As i wouldn't mind a few more herbs outta the '00WR.I suppose the flywheel would still tame it down a bit but every bit helps and the vortex is still mega bucks.
  • ZEHR
Posted July 30, 2007 - 12:49 PM
i took i real quick look on ebay and didn't see any. sorry
  • Mutu
Posted July 30, 2007 - 10:35 PM
Not sure, but should still apply.
Ask a wrecker if you could see if it fits and test ride it. Might not be any difference with the older bikes. :excuseme:
  • Thermos O flask
Posted July 31, 2007 - 03:15 AM
yeah,I might just look into that idea.
