Over flow tube leaking.
3 replies to this topic
  • 01426
Posted July 28, 2007 - 03:51 AM
I just bought an 01 YZ426 and after ridding it last night I noticed the radiator coolant leaking on the ground so I discovered it was coming from the overflow tube. Is this as simple as just actually being to full or is the radiator cap weak or do I have another problem I need to look at?
  • 642MX
Posted July 28, 2007 - 03:59 AM
The radiator was probably over-filled causing it to blow some out. Also, YZF's need a lot of air going thru the radiators to cool efficiently. Riding at low speeds for extended periods of time will cause them to blow coolant too.
I just make 'checking my radiator fluid' a normal part of my maintenance routine.
  • 642MX
Posted July 28, 2007 - 04:01 AM
Opps, I forgot to add that the coolant level should be just over the radiator core and just below the filler neck of the radiator.
  • 01426
Posted July 28, 2007 - 04:04 AM
That's what I was expecting.
Thanks!
  • Hot  47 replies
  • Hot  38 replies
  • 5 replies
  • Hot  30 replies
1998 yz400f will not idle. by trolley
  • Hot  32 replies
