factory torque specs??
11 replies to this topic
  • frankycottonrow
Posted July 27, 2007 - 02:58 PM
Does anyone know the factory torque specs for rear sprocket on 07 YZ 450?? Thanks.
  • Wiz636
Posted July 27, 2007 - 03:05 PM
Off the top of my head I'm going to say 30 ft/lbs...but if you have an '07 I'm assuming you got it new and should have the manual, right?
  • frankycottonrow
Posted July 27, 2007 - 05:11 PM
yeah, about that manual, Its used and I've only had it two weeks. Dude bought it and it was too much so he took it back. I've got the 51 sprocket and o ring chain among other goodies ready to put on so I was just wondering about the tourque specs. thanks:ride:
  • CaptainKnobby
Posted July 27, 2007 - 06:40 PM
I wouldnt worry so much about the torque specs on the rear as long as you use some loctite on the threads:thumbsup: of the sprocket bolts. I use the blue kind and tighten the sprocket bolts down in a crisscross pattern until I get them fairly tite and mine have allways stayed on. They are not that hard to take off either when replacing the rear sprocket.
  • Wiz636
Posted July 27, 2007 - 06:48 PM
I just checked my manual...it is 30 ft/lbs
  • WB450
Posted July 27, 2007 - 07:31 PM
As tight as you can get them should be good.
  • Wiz636
Posted July 27, 2007 - 07:42 PM
Lol...tighten them until it strips then back it off a 1/4 turn.
  • shortburb
Posted July 27, 2007 - 07:44 PM
30/lbs sounds light!
  • Wiz636
Posted July 27, 2007 - 07:52 PM
Why? They are self locking nuts...
I'm guessing that Yamaha knows what they are doing.
  • Yamaha4lyfe
Posted July 27, 2007 - 09:09 PM
no they dont. on my buddy's bike he did no locktite. 30 ftlbs, on self locking bolts. after 3/4 of a moto on the berm after the whoops his sprocket tore apart his rear hub.. id do the locktite at like real tight.
  • shortburb
Posted July 28, 2007 - 05:09 AM
the rear sprocket use to come loose on my 125 fairly easily to where i was checking it every ride....those bolts see all the fury/vibration the motor puts out
Posted July 28, 2007 - 08:23 AM
See if this fixes that for you:
http://www.yamahaown...ook.com.au/?r=0
Perhaps you can explain why I've never had a problem with this, and don't use Loc-Tite on the YZF's (because they have lock nuts)?
If your buddy had a hub that already had damage to the sprocket mounting tabs from being run with a loose sprocket (holes slotted and burred), then that may have contributed, but most of the time, the cause of a rear hub flange being broken is an overly tight rear chain.
Also, when tightening the bolts, hold the bolt, and torque the nut. 30 pounds that way will be tighter than 30 pounds torquing the bolt. I don't generally use a torque wrench for this job, but I'd venture that I run them down more than 30 ft/lbs, too.
In case you're wondering how one would use a torque wrench on the nuts, where a box end is required, use a "torque adapter". This looks like a short box end wrench with a 3/8" square drive socket on one end, and it goes on the torque wrench at right angles to the handle.
