Safety Wire Size
5 replies to this topic
  • Guest_Guest_*
Posted June 28, 2000 - 05:48 PM
Guys:
What gauge of wire do you use to wire your grips and/or other parts on your bike? I bought some 24 gauge steel wire but wanted to ask before using.
  • Guest_Guest_*
Posted June 29, 2000 - 09:22 PM
BTW, the 24 gauge is rated at 10 pounds.
  • Guest_Guest_*
Posted June 29, 2000 - 10:42 AM
You use stainless steel safety wire, not regular steel wire, cause it breaks too easily, its available at aircraft supply shops in 2 guages, I use the lighter stuff which is 25 thousandths of an inch diameter, you will also need a pair of safety wire pliers, about $20 to $30.
  • Kevin_in_New_Hampshire
Posted June 29, 2000 - 12:23 PM
There is available that safety wire thing, I don't even know what it's called, some sort of looped gizmo for twisting safety wire. Skip that goofy thing and like DeBarker said, get real safety wire pliers. I use mine ALL THE TIME. You won't regret it.
  • Heywood
Posted June 30, 2000 - 10:01 AM
I have 0.032" diameter stainless. It is available from White Bros. About $20.00 for a big roll.
And I agree - Definately get the pliers....
[This message has been edited by Heywood (edited 06-30-2000).]
  • Bryan Bosch
Posted July 03, 2000 - 09:26 PM
I've been using standard residential copper wire (romex) and it works great! When you twist the wire it stretches nicely and the knot can be flattend into the grip with a hammer. The bottom-line is that I never had a grip spin on the bar. Even after the grip end was torn and moisture could get under the grip. The wire is cheap too.
