Blowing up a fuel tank
3 replies to this topic
  • RodH
Posted June 28, 2000 - 05:26 PM
Did that get your attention :)
What I mean is the hot water and compressed air trick to expand the tank.
Sidetrack magazine recently wrote that they took a 10lt XR650 tank, and blew it out to fit 11.8lt of fuel. I need more than 8lts, and I think 1 more litre of fuel would be good. Now how do I do this ?
RodH Canberra, Australia<A HREF="http://www.400thumpers.oz-au.com" TARGET=_blank>
400 Thumpers Australia</A>
2000 WR400F See Photo's and Modifications
  • Matt_Porritt
Posted June 28, 2000 - 05:31 PM
ROD..
I know thw WR tanks only blow up another 0.5l.
The YZ tank will prob only get 1l tops.
I can sell you an oversize tank to fit.. IMS 12.4l.. cheap to you also!! (real cheap!) :)
**Ride it like you Stole it!**
Matt Porritt
99 YZ400F
Vist the Rubber Chicken Racing Online Shop
Discounts for ThumperTalk members.
  • gbernard
Posted June 29, 2000 - 03:01 AM
I THINK SIDETRACK BLEW UP THEIR ACROSS AUSTRALIA WR TO ABOUT 11.5l. AND DOSEN'T YAMAHA DO A 15l TANK. JUST LOOKED IT UP, OCT-NOV 1998 ISSUE 21. QUOTE; GENTLE TREATMENT USING HOT WATER AND LOW AIR PRESSURE-PUMPED INTO THE TANK VIA THE BREATHER HOSE USING A HAND PUMP- HAS EXPANDED THE TANK FRON 12l TO 14l. NOTE ADD ONE OR TWO LBS EVERY HOUR OR SO AS THE TANK COOLS;.
THIS ISSUE 21 HAS ALL THE TRICKS THEY DID FOR THE RUN ACCROSS OZ. HOPE THIS HELPS.
CHECK OUYT THE BRIGHT HEAD LIGHTS,FULL SIZE TWIN 60/55 WATTS ON TOP AND 55 WATTS BELOW.
FRON GREG 98WR400
  • Scott_F
Posted June 29, 2000 - 04:12 PM
If anyone tries this, be sure to do it on the bike, otherwise the tank may deform and not fit well.
