For Chris in Utah....
2 replies to this topic
  • rwhitlock
Posted January 25, 2001 - 08:25 AM
Did you do a timing change on your '01 wr426? If so, who did it, and what has the result been?
I am down in Springville and Frandsens is the dealer for me. Due to several posts on the timing change I am wondering if it will make any difference.
Could you let me know how your timing change works out?
Thanks,
Rod
  • Guest_Guest_*
Posted January 25, 2001 - 08:38 AM
Hey Rod,
Do you live by Hunter's Valley and if so was that you riding around the neighborhood a few days ago?
My wr is a 2000 model but I'll let you know how feels when this snow melts and I can go for a cruise. If you have the time, you should do it yourself. An hour or two of swearing under your breath and your done and you've saved money too! I followed James Dean's suggestion and put in the ekp needle with the #100 air jet and the 48 pilot/ 168 main...
It started on the first kick so I hope I wont have to tear her down again too soon.
Lets go ride sometime!
  • rwhitlock
Posted January 25, 2001 - 10:36 PM
Chris,
I live over in the Mike Klauck sub division. Kinda by the white lime spot on the mountain. There are a couple of guys around here that have the wr. I play around by the lime spot as often as I can, then just a bit further north too.
My email is rwhitlock@novell.com if you want to drop me a line.
So it sounds like you are in this area too?
Rod
