Help! Manual says CR8E, I have a CR8EK?
2 replies to this topic
  • jj
Posted June 24, 2000 - 07:14 AM
CR8E, CR8EK what's the difference. I went to change my plug and realized the plug I have isn't the correct one. Can I use it, what will I gain or loose?
I did notice that the old, correct, CR8E had only one electrode and the CR8EK has two, similar to the split fire...
Thanks!
JJ
[This message has been edited by JJ (edited 06-24-2000).]
  • Kevin_in_New_Hampshire
Posted June 24, 2000 - 09:38 PM
JJ,
You are the second person on this websight that has mentioned this. Just an FYI.
  • Bill
Posted June 24, 2000 - 10:38 AM
The "EK" plug is the same heat range as the "E" plug (8). As you stated the only difference is the second ground electrode. I have purchased one and have yet to try it.
Give it a shot and let us know.
Bill
