OEM exhaust baffle insert for 00 WR
3 replies to this topic
  • HGaither
Posted June 19, 2000 - 06:05 PM
Does anyone happen to have an OEM exhaust baffle insert for the 00 WR laying around your house that you don't need ,if so mail it to Harvey Gaither ,1205 shadescrest rd.,Anniston Al.,36206, and I will send you 20 dollars. thanks
  • Guest_Guest_*
Posted June 19, 2000 - 07:49 PM
Hgaither if your going to run stock ex. then install the baffle out of the TTR250 it works good and the noise is not that bad.It will give you a little more top end the opening is larger then the WR400 baffle.
monty
  • Guest_Guest_*
Posted June 19, 2000 - 07:51 PM
P.S. i have the stock baffle you can have it let me know and i'll box it up
monty[wilmexrs@cs.com]
  • HGaither
Posted June 20, 2000 - 02:33 PM
thanks Monty,I'll check the price of the ttr 250 tommorrow at my local shop and get back with you. Harvey
