need help with Clutch problem
Just bought a refurbished asv clutch lever and perch($15 ebay) anway took old one off, put new one on and now there is no tension on the spring where it hooks into push lever. what Im I doing wrong or not doing. took screw out that holds the seat plate in, if i turn that towards rear of bike it has tension but no way to put screw back in. Cant figure it out. so I put it back in the way it was. I looked at my book but it doesnt show or explain it clear enough(I need pictures) the bike is a 2001 426 :confused:
gray you are amazing I used the old perch and presto problem solved. Thank you for everything. your knowledge and willingness to help are the reason why alot of us come to this website. I cant say thank you enough. :prof:?
