cracked crankcase 450 questions?
4 replies to this topic
  • heated450
Posted July 22, 2007 - 01:28 PM
Well,
03 yz450
Ive got a crack in the left hand crankcase half just in front of the front sprocket cuased by a broken chain.
Can the crankcases from the yzf quad 450 motor be used on my 03 yz450? what years? or the cases from a 426 maybe? or what years of yz450 cases will work as a replacement?
Posted July 22, 2007 - 03:42 PM
The only cases that will interchange are those from a YZ450 '03-'05. Everything else is different.
Look into having yours welded and machined if needed.
  • motomanmike26
Posted July 22, 2007 - 03:59 PM
a cheap fix, idk if it will work or not for you but it did for me. i just got some quick aluminum from rocky mtn atv. works great
  • heated450
Posted July 22, 2007 - 04:35 PM
I tried patching it with some similar stuff but its still leaking oil from the push lever where the clutch cable connects.
  • dirtriderr17
Posted July 22, 2007 - 09:31 PM
Well,
03 yz450
well its not only because a broken chain. you probably had the chain to tight, causing the crankcase to crack then having the chain brake...
