help kickstart wont come off 426
4 replies to this topic
  • hillclimb426
Posted July 21, 2007 - 09:18 PM
im in the process of replacing the water pump and seals on my 426 and the kickstarter wont come off. i have tried pullers lube and everything else i can think of.is there some special trick or tool i need.i just got the bike and i dont think the kickstater has every been off.the bike has sat for the last three months got to ride it once and the weap hole started leaking
  • 426 boy
Posted July 21, 2007 - 09:56 PM
yea mate i had the same problem but the echanic managed to split the cases without taking the kickstarter off,
  • hillclimb426
Posted July 22, 2007 - 11:32 AM
do u know how he was able to do this?
  • 642MX
Posted July 22, 2007 - 06:33 PM
Put your kick-starter bolt back in until snug. Pull your kick-starter out as if you where going to start the bike. Leave the kick-starter out and remove the bolt. The flange of the bolt will make contact with the kick-starter and force the kick-starter off of the shaft as you back the bolt out.
  • hillclimb426
Posted July 22, 2007 - 09:08 PM
THANK YOU VERRY MUCH, Will go try that right now!
  • Hot  113 replies
  • 0 replies
  • On January 15, 2017
