Bog off idle
6 replies to this topic
  • Rich331
Posted July 20, 2007 - 09:06 PM
I have a 07 WR450 and it bogs off idle when you blip the throttle. It does affect it on tight slow trails.
Did all the free mods (AIS removal, gray wire, airbox & exhaust mod) put a 170 main jet, adj fuel/mix screw, and went up to a 48 pilot jet Checked the accelerator pump (spot on) and still have the bog off idle. The leak jet is the only thing I have not changed.:banghead:
Is the leak jet the culprit or is there anything else I'm missing? If it's the leak jet, go to a #40??
Thanks for any input.
  • ARin
Posted July 20, 2007 - 09:52 PM
either a 40 or a 35 or a zero(solder shut)
gotta play around with it, see what works.
  • Rich331
Posted July 21, 2007 - 06:16 PM
Thanks.
I not very comfortable with permanently blocking off the leak jet hole though. Has anyone had this problem and found the leak jet cured the issue??
  • clark4131
Posted July 21, 2007 - 06:49 PM
Read through the jetting database to get a good baseline setting, adjust your carb, accelerator pump and idle per the manual and then see what you get...SC
  • trailordune
Posted July 21, 2007 - 08:32 PM
Thanks.
Almost everyone with a wr and even most 4 strokes with an fcr carb has had this problem and yes changing the leak jet does cure the problem for most. I run a #35 leak with great results but think I would be fine with a 40 and save a little fuel. Time for you to see what's right for your bike/area. :ride:
  • Mutu
Posted July 21, 2007 - 11:14 PM
You could lockwire the accel. pump actuator arm.
Free to do and makes a nice difference.
JD jetting kit comes with o-rings that do the same thing.
  • ccoates445
Posted July 22, 2007 - 03:39 PM
I went to the 40 leak and the thicker o-ring in the jd kit. Spot-on.
