yz426 starting tips
9 replies to this topic
  • 426brandon
Posted July 20, 2007 - 04:19 PM
hello, i just bought my 2000 yz426f today, and i have trouble starting it, can any one help me? also, when i start up the bike, it starts good cold, but it gives me a hard time starting when its warmed up/hot
  • dr x
Posted July 20, 2007 - 04:31 PM
Posted from an article in MXA magazine:
Step one: With the transmission in neutral, turn the gas on and pull the choke out.
Step two: Kick the engine through slowly until you come to the hard spot (where the kickstarter will not move). This is called "bringing it up on compression."
Step three: Once you have brought it up on compression, follow these three steps:
(1) Pull the compression release in.
(2) Move the kickstarter about one inch past compression. Do not move the kickstarter so far that the piston goes through compression and moves too far down into its intake stroke. A little dab will do ya.
(3) Once you have nudged the piston over top dead center, allow the kickstarter to return to the top of its arc.
Step four: Release the compression release.
Step five: Kick with a steady but full stroke (from the top of the kickstarter’s arc all the way until the kickstarter hits the footpeg). If you did everything as prescribed, the YZ-F will start. However, if you touched the throttle, it will not.
Throttle tip: instead of holding onto the throttle with your right hand, hold onto the brake master cylinder.
Hot starting tip: Pull the hot start button out and follow steps one through five. Push the hot start button in as soon as the engine starts.
Cold start tip: Before you start the YZ-F for the first time, give the throttle two little blips. This will put a small dose of fuel into the top-end. No more than two blips. Never blip the throttle before starting a hot or warm engine.
Enemy tip: If you don’t own a YZ-F but want to ruin the day of a YZ-F rider who you don’t particularly like, go over to his unstarted YZ and give the throttle four or five healthy twists. The accelerator pump will fill the engine with fuel and it won’t start until the following Thursday.
The word: The Yamaha YZ-F isn’t the easiest starting full-size four-stroke engine made--that honor goes to the KTM 520SX or anything with an electric starter, but the YZ-F will start every time--if you follow the drill..
Posted July 20, 2007 - 07:55 PM
You watch too:
http://www.yamaha-mo...troke_vid_a.mpg
http://www.yamaha-mo...troke_vid_b.mpg
  • C333
Posted July 20, 2007 - 08:02 PM
LMAO!!!! Great post:thumbsup:
  • whyzee79
Posted July 21, 2007 - 05:56 AM
This thread should be stickified :)
Posted July 21, 2007 - 07:45 AM
The videos already are. They're in Common Threads.
  • whyzee79
Posted July 21, 2007 - 09:12 AM
true, but it gets asked alot.
  • Ga426owner
Posted July 21, 2007 - 10:49 AM
patience and decomp fix.....man I do not miss trying to kick them over on the side of a hill :rant:
  • felix 222
Posted July 21, 2007 - 06:15 PM
step one:
use the search feature
  • Dr.Wilson 154 ( . Y . )
Posted August 05, 2007 - 10:49 PM
buy cr8ek plug for it its a double electode and makes my 426 start first kick hot or cold it costs a bit more but really helps
  • Hot  38 replies
  • On January 15, 2017
  • Hot  50 replies
  • 10 replies
  • Hot  30 replies
