  • Instagram
Related Garage
Yamaha WR450F (2007)
Owner: IrideWR
Added on January 20, 2017
Related Reviews
Yamaha WR450F 2004
Last review by jtklein
Yamaha WR450F 2014
Last review by BlueSmoke33
Yamaha WR450F 2011
Yamaha WR450F 2016
Last review by bobkoch
Yamaha WR450F 2005
Last review by Kalamazoo
* * * * * 7 votes
What did you do to your WR today?
Yamaha WR400F Yamaha WR450F
4441 replies to this topic
  • djrevz
Posted August 04, 2010 - 12:20 PM
Had my wr 426 dyno tuned runs perfect. :eek: Thick line= bhp Thin line= torque
Posted ImagePosted Image
02 426
Timing (WR-YZ): yz
Main jet: 168
Main air jet: 200
Pilot Jet: ....
Pilot air jet: 100 PAS
Fuel screw (turns out): 1
Starter jet: .....
Needle model/Clip position: yzf needle, clip 3 from top
Airbox lid (on or off): OFF
Pipe: white bro
Temperature where you ride: 70-80 F (now)
Humidity: 50-60% (now)
throttle positioning sensor disconected.
Let me know of any thoughts anyone has...:banana:
Edited by djrevz, August 04, 2010 - 12:37 PM.
  • djrevz
Posted August 04, 2010 - 12:42 PM
I installed a vapor tech trail speedo. Hooked the rpm wires to the coil, as well as the power wires and everything works except the tachometer. Any suggestions as to how to make the tach work?
Im actually having problems with the rpm reedings, i have fitted the wire to the coil wire (wrapped) and to the live of the coil and reeds to high on the diagram but low on the digits, but the tacho fitted perfect i made a bracket that fitted to one of the front 8mm bolts that hold the fork guards on.
  • flynz
Posted August 05, 2010 - 02:43 AM
I hooked both the power wire and the rpm wire to the coil wire, do you think that could be a problem? I wrapped them around the connector on the wire side. I was contemplating solder and heat shirink tubing which I have, if it worked how it is now, but, no worky. Any suggestions on where to hook the power wire too?
Right now I'm 6,000 miles away from my bike to confirm I believe I only hooked one wire up to the coil and the other to ground on the frame and the power wire goes to the battery. Try doing that.
Edited by flynz, August 06, 2010 - 12:41 AM.
  • schattat
Posted August 05, 2010 - 11:50 AM
Custom fitted an Öhlins steering damper to compliment to rest of my Öhlins setup :banana:
  • ASternad
Posted August 06, 2010 - 08:28 AM
What kind of handlebar riser you running, home made?
  • schattat
Posted August 06, 2010 - 08:45 AM
Yes indeed! The handlebar mounts are from a KTM (for a 28.6mm bar) that are normally fixed with a M10 allen head screw (screw length can be chosen as needed). Just lathed a couple of aluminium risers, got longer screws and mounted it together. It's the identical setup to that used in the rallye kit offered by Yamaha for races like the Dakar:
  • Icelandic_amateur
Posted August 08, 2010 - 01:29 AM
I have a 2005 WR 450, and I have been riding with a friend this summer, he has a WR 450, 2006 model, i.e. 1 year younger than my bike.
In short, it is a shock to find out how much better his bikes handles around courners. Somehow the stear (or the front) seems so high on my bike, and not as "connected to the earth" as on his bike. I have tried to play with the supspencion; by loosing it up, but still it is obvious that his bike handles much better.
I thought that Yamaha didn't change the bikes much between 2005, and 2006. Have you guys had the same experience?
  • flynz
Posted August 09, 2010 - 02:46 AM
You might want to see what front tire he is running I tossed the stock one and put on a 756 my bike it rides like its on rails now:ride:
  • JSanfilippo
Posted August 10, 2010 - 08:38 PM
Sounds like you've got too much race sag. The lower the rear end is, the less weight there is on the front.
Find out the correct rear spring for your weight and install it. Set the sag correctly and it should sort most of the issues you're having. A new front tire will take care of the rest.
Throwing on a better front tire when the suspension isn't sorted is like trying to cover a gash that needs stitches with a bandaid.:banana:
  • jw423
Posted August 12, 2010 - 02:27 PM
Check this out at about 5:44 maybe it will help..:banana:
http://www.youtube.c...Q?fs=1&hl=en_US
  • rholbrook
Posted August 14, 2010 - 08:57 PM
I added a RevLoc Dyna Ring to my WR and went for a ride. I will never own another bike without one. Love it.
  • spick
Posted August 17, 2010 - 03:13 PM
New front sprocket on my 06. 8500km on the stock one. New chain on the way too.
Pretty simple thing to do once I picked up a 27mm socket for my 1/2" ratchet.
  • stev0
Posted August 17, 2010 - 09:57 PM
Interesting. I will look into this when I need to replace my clutch basket.
How does an auto clutch work? Id still like to use my clutch for wheelies and nose lifts over obstacles?
I'm assuming, I loose the clutch completely?
  • OneGuy
Posted August 18, 2010 - 03:10 AM
Installed a DR.D exhaust. Cant believe i waited this long before making this mod.
Now working on installing the 3.3gal tank. :banana:
  • rholbrook
Posted August 18, 2010 - 07:06 AM
No need to replace the basket and installs in 15 minutes. At that low of speeds you really don't need to use the clutch to go over obstacles. You can by the way still use your clutch to get your rpm up to do this. In a way You can adjust the level of clutch you want or should I say what rpm you want the clutch to engage at with the clutch cable you have now. If you adjust your clutch all the way out its almost normal.
  • stev0
Posted August 18, 2010 - 07:40 AM
Im pretty sure id need a new basket some time or another. My basket has about 580hours on it... with a stock clutch.
So when the basket goes, ill look into these clutches. Ive never ridden with an Auto clutch big thumper, so I can imaging it must be AWESOME on the technical terrain.
  • Parx_400
Posted August 21, 2010 - 02:51 PM
Changed it from this:
To this for a 14 hour ride i'm going on tomorrow:
  • stev0
Posted August 22, 2010 - 12:25 AM
I put it up for sale :bonk:
  • jw423
Posted August 22, 2010 - 01:57 PM
I put it up for sale :foul:
Why ohh why would you ever do that! :bonk:
I took the front end apart to regrease the steering stem bearings.
  • TheBlackSheep
    The TT shirts are gay!!
Posted August 22, 2010 - 05:53 PM
I took it on a ride early this morning before it got 100 degrees today :foul:
...... bahhh :bonk:
Wr450f at higher speeds wobbles quite a bit by Turtlerider
Dirt Bike   Make / Model Specific   Yamaha   WR 400/426/450
  • Hot  28 replies
New to the SM world by Kegger_92
Dirt Bike   Special Interest Forums   SuperMoto
Show Us You 2016 WR450f & Mods - last post by Super_Davee
  • 0 replies
Show Us You 2016 WR450f & Mods by chelder
  • Hot  34 replies
Just curious how much i could get for my bike not intrested in selling though by mikerussell97
  • Hot  35 replies
