  • Instagram
Related Garage
Yamaha WR450F (2007)
Owner: IrideWR
Added on January 20, 2017
Related Reviews
Yamaha WR450F 2017
No reviews available
Be the first to review this
Yamaha WR450F 2007
Last review by IrideWR
Yamaha WR450F 2011
Last review by jtklein
Yamaha WR450F 2009
Last review by msowsun
Yamaha WR450F 2004
* * * * * 7 votes
What did you do to your WR today?
Yamaha WR400F Yamaha WR450F
4445 replies to this topic
  • rkwfxd1
Posted July 29, 2010 - 12:49 PM
Well I don't know if this will come out in this post but today I typed up a basic Torque Value Chart for the nuts and bolts I remove the most.
WR PART FT/LBS TORQUE IN/LBS TORQUE
Seat 17 204
Radiator Shrouds 4.3 51.6
Fuel Tank 6.5 78
Engine Guard 5.1 61.2
Oil Filter Cover 7.2 86.4
Oil Drain Bolts 14 168
Front Axle Holder 15 180
Front Axle 65 ---
Rear Axle 90 ---
Valve Cover 7.2 86.4
Spark Plug 9.4 112.8
Upper Motor Mount 40 480
AIS Valve Mount 5.1 61.2
Spark Plug – NGK / CR8E – Gap = .028-.031
  • rkwfxd1
Posted July 29, 2010 - 12:50 PM
Well the "table" did not copy over but you can figure it out the first number is ft/lbs and after the space is in/lbs.
I keep this chart in my tool box and it saves me from looking things up in the book.
  • SPLATT
Posted July 30, 2010 - 06:24 PM
Sounds like an electrical problem, probably the coil, when they crap out they still work fine when they're cold but fail when hot, hence the starting and running fine initially then it refusing to start/run for any period of time again.
Went and checked the coil like you suggested and found it was indeed the culprit. Got it replaced and now it runs again:banana: Thank you again for the heads up on that:thumbsup:
Steve
  • spick
Posted July 31, 2010 - 02:05 PM
Installed a set of Fastway F6 pegs on my 06:
The thing is I installed them in the low-boy position, which all the info says you cannot do on the 2006 WR450F. I had no trouble installing them in the low-boy position. What gives?
  • SPLATT
Posted August 01, 2010 - 09:19 PM
After finally getting it running and back together I took it for a 45 mile ride in my truck only to find out my 15 year old left his boots at home:banghead:
Steve
  • jayh300
Posted August 02, 2010 - 05:17 AM
got a new boot this weekend.... on my broken left ankle on mine....
not much fun
  • stev0
Posted August 02, 2010 - 06:55 AM
who knew 70psi wouldnt pop the bead... but blow the tube... ? and then blow the bead off the rim....
  • tribalbc
Posted August 02, 2010 - 08:12 AM
not much fun
That sucks :banana:
  • tribalbc
Posted August 02, 2010 - 08:13 AM
I never dare going ove 50....
  • jayh300
Posted August 02, 2010 - 08:19 AM
That sucks :banana:
yes it does...going to ortho today
  • davidl9999
Posted August 02, 2010 - 08:48 AM
Good luck with that, Jay. Heal well. :banana:
"I" on the other hand:
Dug a 100' trench, 20 1' holes, 4 2' holes (in decomposed granite, mind you),
planted 10 Malbec vines and 4 pine trees, (10 Zinfandel vines and another pine tree are waiting for today...)
mixed 5 'barrows of compost and dirt, hauled 6 barrows of DG,
and laid 60' of drip watering (another 200' is sitting in the truck)
and looked in the garage as I was putting the tools away, knowing that I wasn't going riding this weekend. :eek:
  • Alexandros
Posted August 02, 2010 - 01:44 PM
I installed a vapor tech trail speedo. Hooked the rpm wires to the coil, as well as the power wires and everything works except the tachometer. Any suggestions as to how to make the tach work?
  • rkwfxd1
Posted August 02, 2010 - 08:20 PM
Well I started on the simple task of cleaning the air filter in prep for Friday's planned ride with my daughter. Then I noticed the stock filter has split at the seam so I purchased a new TwinAir and oiled and installed that.
  • 2in2out
Posted August 02, 2010 - 08:58 PM
Oil change today, and put my mirrors and tail light back on (took them off to ride sweep for a local race). Swiped the plate of my street bike and am going to risk about 10 miles of pavement, and 20 of dirt to get to work tomorrow.
Then 40 miles with a coworker, weds. morning after we get off work.
  • flynz
Posted August 02, 2010 - 11:40 PM
I spliced the tach wire into the coil wire and soldered the wire in place and my tach works flawless you might want to recheck the connections too
  • Alexandros
Posted August 04, 2010 - 03:55 AM
I hooked both the power wire and the rpm wire to the coil wire, do you think that could be a problem? I wrapped them around the connector on the wire side. I was contemplating solder and heat shirink tubing which I have, if it worked how it is now, but, no worky. Any suggestions on where to hook the power wire too?
  • stev0
Posted August 04, 2010 - 04:02 AM
Fren Tubo braided hoses on, bled the system and dropped on a YZ450F open race can.
WOW what a difference! Never knew the stock can choked the bike this much!
  • jayh300
Posted August 04, 2010 - 08:18 AM
no surgery... boot for about 6 weeks...
have it marked on the calendar... sept 5
  • davidl9999
Posted August 04, 2010 - 08:39 AM
Grats Jay!
Ground squirrels destroyed all the vines (20) in 3 days (even ones that didn't get planted yet). Still haven't been on the bike due to work. Meh.
  • jayh300
Posted August 04, 2010 - 09:47 AM
Grats Jay!
thanks..
we had ground squirrels real bad last year.. went to a feed store and got some tainted grain to put in the holes... not near as many this year...
Wr450f at higher speeds wobbles quite a bit by Turtlerider
Dirt Bike   Make / Model Specific   Yamaha   WR 400/426/450
  • Hot  28 replies
2012 wr450 headlight by donkeyballz
  • Hot  27 replies
any reason why to get new Beta 450rr instead of wr450f ? by motf
Dirt Bike   Make / Model Specific   Beta
  • Hot  80 replies
Valve Cover gasket keeps blowing by pbcrazy9898
  • Hot  29 replies
Just curious how much i could get for my bike not intrested in selling though by mikerussell97
  • Hot  35 replies
