  • Instagram
Related Garage
Yamaha WR450F (2003)
Owner: ScubaruSteve
Added on January 16, 2017
Related Reviews
Yamaha WR450F 2009
Last review by msowsun
Yamaha WR450F 2008
Last review by chandic
Yamaha WR450F 2017
No reviews available
Be the first to review this
Yamaha WR400F 2000
Last review by twerth
Yamaha WR450F 2015
Last review by Ken S
* * * * * 7 votes
What did you do to your WR today?
Yamaha WR400F Yamaha WR450F
4438 replies to this topic
  • rkwfxd1
Posted July 10, 2010 - 03:55 PM
Rode it with my daughter and my buddy and his son. Hit El Mirage about 630 and by noon it was over 100 so we loaded up, headed home and straight to the pool. Great day!
Looking forward to cleaning it and checking the valves and changing the oil this week or next weekend.
  • pismowr
Posted July 11, 2010 - 08:07 AM
Went for my 1st test ride with a z-start Rekluse, "amazing" I went easy on it at 1st then once it felt like everything had seated in I went for it and did some technical hill climbs and it shined all the way up, just kick it up a gear and go for it. Then did a tight single track coarse we built and even where I usually stop for a off cambered switch back I rolled right around it. Highly recommend it.:)
  • jayh300
Posted July 11, 2010 - 04:45 PM
ride #2... on my wr450 smartperformance suspension ...
reset preload on rear spring.. backed compression on front forks 6 clicks..
OMG
the harder you ride this thing the better it is.. it felt like it was part of me.. never had any struggles in any situation and VERY good at speed...It flat goes where you point it with no effort at all..
  • L. Euler
Posted July 12, 2010 - 03:30 AM
Installed Quick Shot II, R&D Remote Fuel Screw, Works connection Pro Perch with Hot Start, YZ Clutch Cable (required for new perch), replaced broken cable guides.
  • tribalbc
Posted July 12, 2010 - 07:08 AM
Raced in the canadian Enduro Championships BC round this weekend :)
Some epic riding and racing. The WR held up well as usual but my PMB endo on my YZ exhaust is pretty much toast now, barely held together for the weekend.
Here's some shots from the MX and Extreme special tests.
MX
And the Extreme test. It was Extreme and long, didn't think I could get my heart rate that high :lol:
The wet tire pit from hell, I got stuck every time in that baby :banana:
  • spick
Posted July 12, 2010 - 07:10 AM
On the weekend I installed a Trail Tech Stator, HiD X2 headlight, and a new switch for the works on my 06. I also installed a Magura Jack which was a right PITA to install.
  • jw423
Posted July 12, 2010 - 02:53 PM
I droped the needle down a notch and took the beast out riding. Beat the snot out of both of us and came home washed up the WR and cleaned the chain and lubed.
As a side note I think I've found a great way to warm the chain prior to lube. No riding on the street where I live. I just rotate the chain under a heat gun. Works great about 3 times through and it's just right!
  • ROB450F
Posted July 18, 2010 - 01:39 AM
tarded it and install trail tech vapor kit.
http://www.thumperta...916#post9512916
cheers
rob
  • co-rydr
Posted July 19, 2010 - 01:02 AM
Added: Eunduro Eng. hand guards,Maxi rear tire w/ultra heavy duty tube,Tusk fork air bleeders,FX tank/shroud graphics(for vanity's sake),FMF stainless header.
Tomm: MSR fork seals
  • tribalbc
Posted July 19, 2010 - 05:55 AM
Watch out with those MSR fork seals. I've had 2 sets start leaking very quickly :smirk:
  • SPLATT
Posted July 19, 2010 - 12:12 PM
Pulled the carb for a thorough cleaning after it crapped out on me on Friday. It started fine,idled smoothly while warming up and ran fine for about a half mile and quit. Kicked over until it started and then it would just die refusing to start and then start momentarily and die again.
Steve
  • kevman_101
Posted July 22, 2010 - 09:40 AM
I took the stock muffler off to trade it for an FMF pipe. He bought a WR with a pipe and found it too loud. He was actually ready to trade his WR for a KLR 450 just to get the softer sound hehehe. Good thing I stopped by the dealer yesterday :smirk:
  • gasgaspilot
Posted July 25, 2010 - 03:50 AM
A long wheelie
and done some laps :smirk:
  • Powerage
Posted July 25, 2010 - 04:36 AM
Cleaned and Re-oiled my Airfilter ~ B B B B B Boring!
Just caught up on the last 15 or so pages of this thread, and i have to say i still really like the look of the Steel Framed WR's. Not sure what it is about them. :smirk:
  • 2006wr450f
Posted July 26, 2010 - 09:49 AM
I made a video slideshow of my WR
  • Alternative
Posted July 27, 2010 - 08:55 PM
Steve
Sounds like an electrical problem, probably the coil, when they crap out they still work fine when they're cold but fail when hot, hence the starting and running fine initially then it refusing to start/run for any period of time again.
  • SPLATT
Posted July 28, 2010 - 10:47 AM
Thanks for the heads up.
Steve
  • jayh300
Posted July 28, 2010 - 10:56 AM
On ride #3 on my WR after the smartperformance suspension redo....
going fast enough to tear stuff up now... my big toe on my rh foot feels about the same
  • davidl9999
Posted July 28, 2010 - 11:21 AM
The freezer will fix that. :smirk:
  • jayh300
Posted July 28, 2010 - 11:24 AM
that is what i am thinking also...
2012 wr450 headlight by donkeyballz
Dirt Bike   Make / Model Specific   Yamaha   WR 400/426/450
  • Hot  27 replies
  • 0 replies
Just curious how much i could get for my bike not intrested in selling though by mikerussell97
  • Hot  35 replies
2015 wr450 engine knock. Video inside. by cdf450
  • Hot  60 replies
New to the SM world by Kegger_92
Dirt Bike   Special Interest Forums   SuperMoto
