  • Instagram
Related Garage
Yamaha WR450F (2009)
Owner: dawataboy
Added on December 04, 2016
Related Reviews
Yamaha WR450F 2007
Last review by cbsander
Yamaha WR400F 2000
Last review by twerth
Yamaha WR450F 2011
Last review by jtklein
Yamaha WR450F 2008
Last review by Zippo638
Yamaha WR450F 2004
* * * * * 7 votes
What did you do to your WR today?
Yamaha WR400F Yamaha WR450F
4430 replies to this topic
  • CanadianWR450
Posted March 27, 2009 - 10:29 AM
Top end rebuild time.....got the top end apart, poked around to see what was needed...my cam chain was WHIPPED! So bad it scored the cam sprockets...I probably could have gotten away with them (the lobes, etc was perfect), but, well, good exuse for Hot Cams.
So, 2 brand new Hot cam's, FMF PowerCore, rings, cam chain, adjustable fuel screw, new Race Tech back spring with the correct rate for me...gaskets, seals, valve guides...etc..etc....
Now just got to get it back together....I'm expecting a big difference in the bike with the powercore, and cam's....if not, I'll be quite disappointed!
  • SPLATT
Posted March 27, 2009 - 04:39 PM
I finally got around to washing it seeing that I didn't have a chance to do it when I got home after my last ride. Now to do an oil change and do the o-ring mod on the carb.
Steve
  • ch_250
Posted March 27, 2009 - 08:05 PM
I also routered out the cross bar pad and inlaid my vapor speedo/tach/temp gauge ect. into it.
That's awesome. That looks sweet. i wonder what would happen though if you smoked your face off the pad where the speedo is now. I've done it before, that would be my only worry.
  • flynz
Posted March 28, 2009 - 04:44 AM
Checked the valves after 800 miles 1 was a little tight so I adjusted it :thumbsup: and put my summer needle in.
Now I'll ride it hard all weekend.:lol: :usa:
  • sdg8569
Posted March 28, 2009 - 11:01 AM
ch250 Its a supermoto bike so my face hitting the crossbar is the least of my worries.:thumbsup: LOL
  • kikkokrash
Posted March 28, 2009 - 12:54 PM
As some of you might know, the WR450F MY2003 had quite a big problem on the Electric Starter, this was solved out in the MY 2004.
I wanted to do the upgrade of the Electric Starter but it would cost to me approx $300 of spareparts (plus shipment expenses, plus my mechanic manpower), then I have decided to save some money and changed only the Electric Starter broken.
In Italy an OEM Electric Starter costs approx $400, so I have adapted a brand new Kimko 150cc scooter Electric Starter (actually my mechanic did) for approx $50, and intalled in my WR.
It works perfectly, better than the original!!!
  • ch_250
Posted March 28, 2009 - 08:01 PM
sdg8569: although i've seen supermoto guys do some pretty fair sized jumps, you're right it's probly the least of your worries. That would be MY main worry though. I think i might take the risk though, it looks awesome. does handlebar vibration bother it any?
  • sdg8569
Posted March 29, 2009 - 05:55 AM
CH250 No it seem that the foam in the cross bar pad dampens the vibration so its not a problem. It actualy make it easier to read the gauges due to the extra rise.
  • fbodysilly
Posted March 29, 2009 - 06:38 AM
Viva Italia!
  • silky666
Posted March 29, 2009 - 02:02 PM
My trusty old '99 WR400.
Installed alloy sump guard.
Fitted some comp3 tyres.
Changed all oil and filters.
Fitted a wavey disc and new pads.
Put on some new graphics (the old original yellow ones were starting to look a little ropey :-)
  • trailman006
Posted March 29, 2009 - 02:19 PM
Received my ThumperTalk order on friday,Thanks Nick.Installed Eibach .50kg fork spring and Seal Savers on saturday and rode 30+ miles of single track in the rain and mud on sunday with friends and family. Life is good.
  • 123BigcoopDawg576
    TT Titanium Member
Posted March 29, 2009 - 06:18 PM
Life is good.
+1 :thumbsup:
  • Paollo
Posted March 29, 2009 - 10:59 PM
rode her on a blast in the road with some of my ride buddies
  • sdg8569
Posted March 30, 2009 - 01:58 PM
What is the p/n of those graphics? I need a set.
  • ARyder
Posted March 30, 2009 - 02:37 PM
First ride with my ProAction Suspension done. Took my son out for a ride since he insisted on going out. It had rained quite a bit and he wanted to go splash his 50 thru the water. He wasn't lying either! He hit some water that went up the the seat. I couldn't have been a more proud dad :-)
The suspension on the WR is awesome. All the little stuff I dont' even feel anymore and I can actually get airtime now without bottoming. I hit my favorite whoops section and really felt the difference there.
On the down side, the suspension cleared the way for me to see the shortcommings of the WR all choked up. In 3-5 gear, the bike falls flat on it's face in the midrange and won't pull hard at all. I dragraced a YZF450 quad and he beat me. Time to uncork this thing to take full advantage of my suspension. Been looking on ebay for a yz450 stock exhaust or a PMB insert..no luck so far.
  • JSanfilippo
Posted March 30, 2009 - 02:59 PM
http://cgi.ebay.com/...sQ5fAccessories
There ya go ARrider! Your welcome
  • ARyder
Posted March 30, 2009 - 03:21 PM
Thank you ! One question though, do I need to still get the PMB insert with this or is the OEM YZ450F just as good, or better than putting the PMB insert into my WR pipe?
  • JSanfilippo
Posted March 30, 2009 - 04:04 PM
OK the PMB insert (bigger baffle) is for the stock pipe to free up some flow. It does add performance but probably only about 1/3 the HP that a free flowing muffler will add. http://www.promotobi...cdedc12bee3d8e2
With the YZ exhaust you'll need some type of spark arrestor if you intend to ride on public land or on private property in densly wooded areas. Its not so much that these engines spark or belch out fire (unless its jetted super rich), but even hot debris or muffler packing flying out of a muffler can start a fire. PMB makes it easy by making a rivet in spark arrestor for the YZ exhaust.
Another option you have is to buy a replacement cone spark arrestor (usually $20-$50) from another brand of muffler and rig it into the stock YZ muffler. These will be USFS approved however the burden of proof will be on you to prove that it is. Usually a ranger out in the field will do a "stick test" to make sure the stick won't go through the spark arrestor.
  • ARyder
Posted March 30, 2009 - 04:20 PM
Thanks for the input. I've never been checked for a spark arrestor here and I don't ride on public lands. I can always get a spark arrestor later on.
Now onto the AIS removal kit, free mods and JD jet kit. :-)
  • buspilot
Posted March 31, 2009 - 12:45 AM
On Sunday my WR 450 and I rode a "Ballade" (Offroad-Ride) in Belgium...
4 Hours for 77 KM... :thumbsup:
Two weeks ago...
Show Us You 2016 WR450f & Mods by chelder
Dirt Bike   Make / Model Specific   Yamaha   WR 400/426/450
  • Hot  34 replies
  • 0 replies
Should i switch to a ktm 300 exc or xcw from a 2009 wr 450f by Tattoojunk
  • Hot  55 replies
Kickstarter Noise by JohnClaude
  • 7 replies
05 wr450 oil leaking from fuel tank mounting hole by gee-tee
  • 0 replies
