  • Instagram
Related Reviews
Yamaha WR450F 2017
No reviews available
Be the first to review this
Yamaha WR450F 2008
Last review by chandic
Yamaha WR450F 2007
Last review by cbsander
Yamaha WR450F 2003
Last review by Dave in Illinois
Yamaha WR450F 2004
Last review by jtklein
Related Garage
Yamaha WR450F (2009)
Owner: msowsun
Added on January 02, 2017
* * * * * 7 votes
What did you do to your WR today?
Yamaha WR400F Yamaha WR450F
4436 replies to this topic
  • 2strokeYardSale
Posted April 18, 2016 - 12:31 PM
KYB SSS rebuild with .46 springs and swap.
Seat Concepts low comfort foam and cover, Tugger strap.
Dirt Bike Gear rear fender bag.
Tusk front fender tube bag.
License plate.
  • Agazza
Posted April 18, 2016 - 11:25 PM
https://goo.gl/photo...ZtGTdcUkUDQ5Kf6
had a quick lock at the new timber trail roads.
I have a problem, a quick twist of the throttle and the engine dies for a short while.
I have JD jetting kit, i have opened up the exhaust and airbox. It was fine this winter, but now when its warmer meaby i need to turn in the fuel screw?
Its about 1½ twist out.
I put in the recommended jetting kit.
im also thinking of getting a full YZ exhaust, is it loud? Is it worth it?
  • 2strokeYardSale
Posted April 20, 2016 - 07:54 AM
I installed an IMS fuel tank with 2006 WR petcock on my 2007. It fit great until I tried to put the seat back on and the bolt holes didn't line up.
  • toten
Posted April 20, 2016 - 08:08 AM
I was under the impression that steel and aluminum frame tanks are significantly different, and not easy to swap. Then again, 400/426 can swap on 450 plastics if they make some adapters so it may be possible.
  • Spiritwalker2222
Posted April 20, 2016 - 08:21 AM
Maybe it's just the petcock that's from a 2006 bike and not the tank.
  • toten
Posted April 20, 2016 - 09:04 AM
I don't think the petcock bolts to anything other than the tank so I'm not sure how it would make anything else not line up.
  • 2strokeYardSale
Posted April 20, 2016 - 03:00 PM
07-11 IMS tank, 06 Yamaha petcock points the outlet toward the carb
  • toten
Posted April 20, 2016 - 05:06 PM
I don't understand what that has to do with bolt holes.
  • 2strokeYardSale
Posted April 21, 2016 - 07:59 AM
Plumbed the petcock, bled the brakes, took some pics.
  • Northern Pride
Posted April 21, 2016 - 04:50 PM
I installed a 2 inch frogskinz on my airbox for better breathing. I run these on my
Snowmobiles to get engine heat out of the cowel to save belts. Amazing product, no moisture allowed through but air is
  • franklinx14
Posted April 24, 2016 - 02:39 PM
Just bought a wr426 a few weeks ago. Already i got sick of the paint wear and chipping from boots on the frame of the bike. So "rhino lined"
the parts that were getting the most contact with boots. I did this with a roll of tape i found on amazon originally to put on steps getting into cars. It is the texture of truck bed liner. after applying it i heated it up to make sure it was on there good and it has held up to my pressure washer perfectly since. i also like the black color it adds to the bike
  • 2strokeYardSale
Posted April 25, 2016 - 09:02 AM
Tracked down its water leak to the pump weep hole. Tore it apart and found the problem.
Worn shaft and a completely trashed seal. Pulled the seals and bearing and ordered new parts.
  • ftl900
Posted April 25, 2016 - 09:53 AM
New head gasket, powdercoated both sidecases while the engine was out.
Looks a little rich so we're dialing back the jetting a bit.
Hoping to have it finished and go riding this weekend!!
Hey, I have that same license plate!!
License plate.
Edited by ftl900, April 25, 2016 - 09:58 AM.
  • mattf450f
Posted April 28, 2016 - 11:16 PM
Nothing.....never say die.......carnt seem to kill it
Edited by mattf450f, April 28, 2016 - 11:17 PM.
  • bobo1020
Posted April 29, 2016 - 04:45 AM
Installed new shoes Michelin AC-10's. (I needed the DOT rating)ImageUploadedByThumper Talk1461933891.153398.jpg ImageUploadedByThumper Talk1461933906.620667.jpg ImageUploadedByThumper Talk1461933915.206575.jpg
  • 2strokeYardSale
Posted April 29, 2016 - 04:14 PM
Took it for a little shakedown ride after all the recent changes. No problems, but it does pop a lot on deceleration, despite the lack of AIS.
  • Northern Pride
Posted April 30, 2016 - 03:24 AM
Installed new shoes Michelin AC-10's. (I needed the DOT rating) ImageUploadedByThumper Talk1461933891.153398.jpg ImageUploadedByThumper Talk1461933906.620667.jpg ImageUploadedByThumper Talk1461933915.206575.jpg
Let us know how you like those, i run dunlop d606. Always wanted to try those tires you put on
  • bobo1020
Posted April 30, 2016 - 03:34 AM
I will keep you updated on how they perform and wear. I do 90% off-road riding so hopefully they hold up for a while
  • VTForester
Posted April 30, 2016 - 11:26 AM
Did a little practice until I got too wet and cold, then cleaned it up and did all new graphics and jewelry.
031CFAE3-4563-40ED-AF75-70E3D5CB57C9_zps
08887B73-4C94-4C06-B20B-64FC2808A0F9_zps
Edited by VTForester, April 30, 2016 - 11:27 AM.
  • patrick2wd
Posted May 01, 2016 - 03:35 AM
I had to decide that my new WR purchase has been postponed by one year.... :thumbsdn: :( :rant:
Show Us You 2016 WR450f & Mods by chelder
Dirt Bike   Make / Model Specific   Yamaha   WR 400/426/450
  • Hot  34 replies
Valve Cover gasket keeps blowing by pbcrazy9898
  • Hot  29 replies
Just curious how much i could get for my bike not intrested in selling though by mikerussell97
  • Hot  35 replies
05 wr450 oil leaking from fuel tank mounting hole by gee-tee
  • 0 replies
  • 0 replies
