  • Instagram
Related Garage
Yamaha WR450F (2013)
Owner: 20 A
Added on January 16, 2017
Related Reviews
Yamaha WR450F 2011
Last review by jtklein
Yamaha WR400F 2000
Last review by twerth
Yamaha WR450F 2008
Last review by chandic
Yamaha WR450F 2003
Last review by ScubaruSteve
Yamaha WR450F 2015
Last review by Ken S
* * * * * 7 votes
What did you do to your WR today?
Yamaha WR400F Yamaha WR450F
4445 replies to this topic
  • Mxnut1994
Posted March 19, 2016 - 07:41 AM
Put on a Lexx Slip on exhaust, sounds absolutely great. Little bit of a power boost from it. Also installed the Applied racing ais removal kit and tinkered with the carb some, and the bike is 1000x better. Only real issue i have left to solve is that wonderful impeller shaft leak and she should be ready to ride!
  • chelipeWR
Posted March 24, 2016 - 08:20 AM
Rigged up a rechargeable bike light to illuminate my license plate. Lil gorilla tape never hurt anyone :p
Edited by chelipeWR, March 24, 2016 - 08:20 AM.
  • DRZ04
Posted March 24, 2016 - 08:40 PM
Got the new adaptor to fit a newer yz number plate.
What is the adapter and where did you get it?
  • Madisyamaha
Posted March 24, 2016 - 08:45 PM
For my 2004 triple clamps it bolts on the front so u can mount the newer style number plate. If you take the headlight off. I did for racing. It's from applied racing
  • Agazza
Posted March 25, 2016 - 12:15 AM
Tried to get it as high up as I could but the snowmobile trails are getting soft on me
Edited by Agazza, March 25, 2016 - 12:18 AM.
  • still2smokin and patrick2wd like this
  • Like This
  • 2strokeYardSale
Posted March 25, 2016 - 09:26 AM
Rejetted my 2007 WR450F
main 162 to 165
pilot 45 to 48
stock needle shimmed with a washer (at most 1 clip position if it had them)
leak jet 60 to 50
fuel screw 2 turns out
o-ring added to accelerator pump arm
I also removed the plastic piece under the airbox snorkel (which was previously removed) to open the airbox even more.
The bike has a full Pro Circuit Ti-4 exhaust and I'll be installing a quiet insert when it arrives.
I ride at 4800 ft to 7000 ft, 30F to 80F. Mostly about 5500 ft and 50F. I do want to ride it in Baja in January, sea level to 2000 and up to 80F(?). Please let me know if I'm off on the jetting. Should I get a NCVS or NFLR needle before putting it back together? Does it need different starter and pilot air jets?
I just bought it, my first 4 stroke dirt bike besides dual sports from long ago, and I only rode it once. I found it lacked power in the low to mid range. It has the usual WR mods (throttle stop, grey wire, snorkel). I have been riding 2 stroke 250s for years, and my YZ250 makes more low-mid than this 450.
  • knuckleduster271
Posted March 25, 2016 - 02:53 PM
Made a dyno run....
Typical spring day in ohio-
90% humidity=shitty #'s.....
  • Eric Landmark
Posted March 25, 2016 - 03:42 PM
Rebuilt my forks with oem Yamaha seals and bushings
Greased my steering stem bearings
Put my new two brothers carbon full system on (07-09 yz450f)
Put in a opt 7 hi LO led head light bulb and blue marker
Tusk compact control switch to replace the old eBay special
Finished up my sicass racing key switch ImageUploadedByThumper Talk1458949118.689015.jpg
ImageUploadedByThumper Talk1458949259.097790.jpg ImageUploadedByThumper Talk1458949290.717737.jpg ImageUploadedByThumper Talk1458949312.587579.jpg
  • still2smokin and RockerYZWR like this
  • Like This
  • RockerYZWR
Posted March 26, 2016 - 09:55 AM
Took apart the back end to clean and lube all bearings (it had never been done on this bike - ever) and clean up all the aluminum pieces. Should have taken the carb off to clean it as long as I was in there but said "eh." It starts and runs fine as is.
  • MidlifeCrisisGuy
Posted March 26, 2016 - 05:47 PM
Can you find the Blue in the sea of European bikes ?   At least this ride had a couple 4ts in it - usually it is just my WR and a bunch of 2ts.
The snow is gone on the south facing slopes.  A lot of climbing to get up this high.   That grass is slippery where the frost is out.  Pin it and hold on.  Fun times.
Everyone is running studs in these pictures, even if you can't see them.
Yes it was snowing in the last picture.   We saw sun, snow, sleet and ice pellets several times throughout the day.  Covered a bit under 25 miles.  Great ride.
Edited by MidlifeCrisisGuy, March 26, 2016 - 05:53 PM.
  • RockerYZWR
Posted March 26, 2016 - 08:00 PM
Man, some of you guys have nice places to ride. Florida (where I am, anyway) really kind of sucks for the most part.
  • 2strokeYardSale
Posted March 27, 2016 - 07:12 AM
Removed chain and sprockets.
Greased swingarm and link arm bearings.
Installed YZ450F shock with stiff spring.
Installed Tusk chain guard.
Replaced corroded rear brake pin with new, extended hex head pin.
If someone (KRANNIE) could help me with my jetting question in my previous post in this thread, I'd appreciate it.
  • 2strokeYardSale
Posted March 27, 2016 - 09:58 PM
New chain and sprockets (14/50), valve check, new spark plug, removed exhaust caps with stuck screw, repaired the hole in the airbox.
  • Chippoy
Posted March 28, 2016 - 03:49 AM
426068_3178110565676_461462985_n.jpg?oh=
  • falconjet
Posted March 28, 2016 - 09:27 AM
Installed turn signals, horn and tail/brake light.
Next step...head to DMV.
  • bobo1020
Posted March 28, 2016 - 03:30 PM
I installed a power outlet for my GPS. Will need it for the MCCCT trail this summer.
  • simica
Posted March 28, 2016 - 06:11 PM
Good luck at the DMV, rear turn signals on motorcycles in California have to be nine inches apart that's why the closest you will ever see are mounted on the outside edges of the license plate.
  • The Salt
Posted March 29, 2016 - 03:45 AM
Nice....  Do you have part numbers for the Lights?  Cost?  Where did you get them?
  • Eric Landmark
Posted March 29, 2016 - 04:14 AM
OPT7 Motorcycle LED Headlight Kit w/ Arc-Beam™ Clear 6K Cool White - 40w 3,500Lm CREE (H4, 9003) - 2 Yr Warranty https://www.amazon.c...d_jeN-wb1DM6EZF
Amazon 60$
I haven't had the chance to see them in the dark yet so I'll update once I do. Assuming they are super bright but we will see!
  • The Salt
Posted March 29, 2016 - 11:33 AM
Amazon 60$
Awesome... thanks!
Should i switch to a ktm 300 exc or xcw from a 2009 wr 450f by Tattoojunk
Dirt Bike   Make / Model Specific   Yamaha   WR 400/426/450
  • Hot  76 replies
Wr450f at higher speeds wobbles quite a bit by Turtlerider
  • Hot  28 replies
New to the SM world by Kegger_92
Dirt Bike   Special Interest Forums   SuperMoto
Washington
The Teanaway is no BS! by Nuklhed
  • Hot  55 replies
Show Us You 2016 WR450f & Mods - last post by Super_Davee
  • 0 replies
